weekend fun
Old Jul 7, 2008 | 04:01 PM
  #76
ralliartist's Avatar
good thread.
Old Jul 7, 2008 | 04:14 PM
  #77
fballman1987's Avatar
the next thing is how can we get 300whp on a street tune with this blower, what insanity will happen if that is possible, and what mods will we need to do it... besided the blown 4 banger mod. lol.
Old Jul 7, 2008 | 04:17 PM
  #78
an0malous's Avatar
without dipping into the motor, youll probably need 2.6 full boltons and meth.
Old Jul 7, 2008 | 04:32 PM
  #79
Area47's Avatar
Rent me! per hour
and a hell of a prayer.
Old Jul 7, 2008 | 04:48 PM
  #80
BlackSS/SC's Avatar
Sweet baby Jesus!
Old Jul 7, 2008 | 04:51 PM
  #81
Blown 4-banger's Avatar
Originally Posted by 06black
how did you get jacked that hard?
our builds mirrored one another, 98% at least, i did all the labor and worked deals on all my parts....about a 1/3rd of your price there.
So you got custom pistons, custom rods, custom cams, custom valves, 30+ hours of labor machining the crank, $1200 worth of cryo freezing, a $1200 clutch, $800 axles, 20+ hours of head work, and $1000 worth of gauges. Not to mention the n/b shafts, and adjustable cam gears. I tallied ALL the expenses, not just engine stuff.
Also, actual cost of my build thus far (not including some misc stuff), is $2700. For everything.
Old Jul 7, 2008 | 04:55 PM
  #82
Area47's Avatar
Rent me! per hour
Originally Posted by BlackSS/SC
Sweet baby Jesus!
im the middle aged fuzzy jesus. the baby is sleeping.
  #83
I think a 2.6 would just make too much heat
Old Jul 7, 2008 | 05:01 PM
  #84
an0malous's Avatar
agreed, but without opening the motor up, i dont think youll do it with a bigger pully.
MAYBE with a 2.7 on a friendly dyno jet
  #85
With my porting and intercooler mods, with a 2.6" at the end of a 1/4 mile run, my IAT2 would be ~125*. Thats starting the run at ~75-80*.
Old Jul 7, 2008 | 05:03 PM
  #86
that's really good, but I still think a lower iat will be needed to crack 300whp. Not only that, but the lower the pulley, the less efficient you make the blower.
Old Jul 7, 2008 | 05:09 PM
  #87
chad463's Avatar
Those are some awesome numbers. I am soon to be getting my meth kit and was wondering if I should just run straight water until I get tuned for it just for the cooling mods? You guys seem to be the ones who would be able to answer this question.
Old Jul 7, 2008 | 05:22 PM
  #88
Area47's Avatar
Rent me! per hour
it's your call really.
just fwiw. my iat2's at the end of the run was 147 at 126 mph or 7800 rpms. started at 122. once past 7k. the temps started going up quick. gee wonder why
Old Jul 7, 2008 | 05:33 PM
  #89
Josh@ottp's Avatar
Time for a HTV
Old Jul 7, 2008 | 05:36 PM
  #90
Area47's Avatar
Rent me! per hour
time to sell 240z first. im a baller on a budget
Old Jul 7, 2008 | 05:40 PM
  #91
WSFrazier's Avatar
Originally Posted by fast98
Time for a HTV
From what I've seen and driven first hand, Turbo > HTV As much as I hate saying it.
Old Jul 7, 2008 | 05:42 PM
  #92
Josh@ottp's Avatar
or you could sleep with 50 fat chicks for $50 each.......
Old Jul 7, 2008 | 05:43 PM
  #93
Area47's Avatar
Rent me! per hour
id rather stab myself in the nuts with a plastic spork
ws. neither of those cars hook!
Old Jul 7, 2008 | 05:57 PM
  #94
overspinning the blower would be my guess, way out of it's efficiency on a 2.7 above 7K engine rpms.
Old Jul 7, 2008 | 05:58 PM
  #95
06black's Avatar
pistons, check
rods we had at work, weeee
cam's, check
dident do valves, i'll give you that.
crank was done by a local race shop that owed me several "tune this F-body" favors
axles i've had for a bit now.
could not say how many hours are into the head, since i dident do it, but i do know the flow numbers are superior to anything else i could have bought or got my hands on.
neutral balance shafts, check
cam gears, check (they cam back to bite me in the ass, make sure you go FAR AND ABOVE the spec'd torque)
gauges, i had some and added to.
"(AFR, interceptor, EGT, Boost, oil pressure)
the trans had been cryo-d in the past and the new engine parts got the same treatment.
that was done with a small cost from a shop we use here at work.
so yea all and all.....yea.
I still cant see how you got that preveously mentioned total...crazy!
I'm not trying to make this a pissing match cam, just stating that you paid a ****** boat load for your project.
such devotion should be commended.
+1!!
Old Jul 7, 2008 | 06:01 PM
  #96
Area47's Avatar
Rent me! per hour
egt was free. nutfuck
so the cam gears were the noise?
you double posted.
again.
Old Jul 7, 2008 | 06:57 PM
  #97
06black's Avatar
you double posted.
again.
when i find the designer of said piece, i'm going to find his/her PE and kick him in the nuts....
man needs to learn how to set a torque spec.
pm to continue if you wish.
Old Jul 7, 2008 | 07:21 PM
  #98
Doc's Avatar
Doc
Old Jul 7, 2008 | 07:28 PM
  #99
M-Dub's Avatar
Squish... PM me your meth recipe....
Old Jul 7, 2008 | 07:38 PM
  #100
ColeJJones's Avatar
Bannned
im not to savy with cams. whats the big difference between the GM cams and the JBP tri-flows?
