Weird Problem
Old Oct 13, 2008 | 08:43 PM
chad463's Avatar
Weird Problem
So I was out driving today everything was fine until I came to a stop. I floored the car in first and at around 5k the car would sputter and the exhaust sounded like a machine gun. It did this a few times so I turned the car off and tried to figure out what was wrong. Couldnt find nothing, no engine codes came up. So I drive it to my house and it still does it again in first, so I get on the highway and floor it in second and nothing. It only seems to sputter and sound like a machine gun in first. Any ideas what this could be? I was thinking spark plugs or clogged cat but I thought it would do it in all gears if it was that. Any help would be awesome.
Old Oct 13, 2008 | 08:45 PM
slowswap's Avatar
Does it sound like a WRX? Its time for a compression test.............
Old Oct 13, 2008 | 08:46 PM
KillerBee's Avatar
It does sound like you might have lost a ring or piston!
D4u2s0t's Avatar
are you spinning the tires and hitting the rev limiter? that's what it sounds like. the rev limiter comes QUICK in first, and the rpms don't always catch up to the actual speed
chris88z24's Avatar
Wheel hop? Not sure why it would only do it in first if it was anything else...
XM15's Avatar
What might be happening is that because 1st goes by so fast, you may be hitting the redline by accident, thinking that you still have another thousand rpms or so before you need to shift.
Old Oct 13, 2008 | 08:49 PM
chad463's Avatar
nah its not the rev limiter I know what its like to hit that, its like before it gets to rev lmiter it sounds like a machine gun. But only in first which is the messed up thing.
Old Oct 13, 2008 | 08:52 PM
chris88z24's Avatar
Wheel hop. Does it do it if you accelerate slowly to redline?
Old Oct 13, 2008 | 08:53 PM
chad463's Avatar
no it dont do it when I go slowly to redline. But I had wheel hop before and it never sounded like this. The exhaust sounds like a machine gun.
Old Oct 14, 2008 | 06:51 PM
mopartech's Avatar
maybe a bad plug or coil ???
loaded up would make that happen.
no codes ???
Old Oct 16, 2008 | 11:58 AM
chad463's Avatar
no codes. I am going to pull the plugs this weekend.
Old Oct 16, 2008 | 12:02 PM
ShortStack's Avatar
Possibly bad gas?
Not from tizzle bizzle... from the gas station
Old Oct 16, 2008 | 12:03 PM
chad463's Avatar
hmm that could be it. I used a different gas station for the first time this fill up.
Old Oct 16, 2008 | 12:07 PM
ShortStack's Avatar
The stumbling would cause the exhaus to probly over rattle and make a weird noise...
I dont think the machine gun noise was anything itself going wrong.
Old Oct 16, 2008 | 07:58 PM
chad463's Avatar
yah I never heard anything like it.
Old Oct 17, 2008 | 08:51 AM
Zach06CobaltSC's Avatar
Check the plugs, and use up all your gas real quick, refill it, through in some heet to raise the octane, and some fuel injector cleaner and see if it helps at all.
I think you should buy a meth kit lol but thats completely off topic. Actually not really, because if it was somehow bad gas even though its not because it wouldnt only be doing it in 1st gear lol, the methanol would help that immensely. You could run 89 with methanol and be just fine, its all in the tuning though.
Old Oct 17, 2008 | 09:41 AM
chad463's Avatar
I do have a meth kit lol. I will check the plugs though everything seems to be pointing to that.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
