Weird problem when starting car..
Old Aug 18, 2010 | 12:49 AM
xxxxsh4d0wxxxx's Avatar
Okay, so, sometimes, the car will start as soon as you turn the key.. The normal 1-2 cranks, and it fires up like a champ.. Now, randomly, every 15 starts (or so), the car will crank 4 times before it starts. What would cause this inconsistency? It is completely noticeable, and horribly irritating.
Old Aug 18, 2010 | 01:55 AM
Dainslaif's Avatar
Crank position sensor crapping out would be my guess, but it's just a guess.
Old Aug 19, 2010 | 09:56 PM
Any other ideas?
Old Aug 19, 2010 | 10:29 PM
1fastSSBalt's Avatar
I would check your starter/wires check connections
Old Sep 1, 2010 | 04:53 PM
Bump.
Old Sep 1, 2010 | 06:26 PM
insylem's Avatar
Lower battery charge?
Diffrent Air Tempature?
Diffrent Humidity?
Old Sep 1, 2010 | 07:48 PM
chris88z24's Avatar
leaky injector
Old Sep 1, 2010 | 10:57 PM
ben_gary's Avatar
A check list for you.
1.fuel in tank
2.battery terminal connections loose or corroded
3.worn, faulty or incorrectly spark plugs
4.broken, loose or disconnected wires at the ignition coil(s) or faulty coil(s)
5.fuel injector(s), fuel pump, fuel filter, pressure regulator
Old Sep 2, 2010 | 02:34 AM
insylem's Avatar
What do you mean by crank? You mean the number of times you have to turn the key to start it?
Or the number of times you hear the crankshaft rotate?
Old Sep 2, 2010 | 02:55 AM
1.fuel in tank
1. I have ran 93 since I got the car about 2 months ago. It is stock besides GMS2.
2. Will check tomorrow morning.
3. Brand new plugs, (And fuel filter), were installed by myself when I first noticed the problem. Didn't fix anything.
4. Will check tomorrow morning.
5. New fuel filter was installed like I said above.
Maybe that information well help narrow it.
Times you hear the crank rotate. I'll turn the key once, and sometimes it'll rotate 2 times, like it should.. And, other times, it will crank like 5 times.
Old Sep 2, 2010 | 12:36 PM
Battery terminal connections are clean and secure. Wires to the coils are connected, not broken or loose.
Old Sep 2, 2010 | 01:00 PM
insylem's Avatar
But it still starts!
Sometimes cars just take longer to start, could be the weather.
Personaly I think your chaseing ghosts, and looking for a problem
where there isnt one.
Old Sep 2, 2010 | 09:36 PM
ben_gary's Avatar
air filter clean?
Old Sep 2, 2010 | 11:05 PM
air filter clean?
Yes sir!
Old Sep 2, 2010 | 11:29 PM
Axelthered05's Avatar
... mine did that for the longest time went away after I replaced the battery havent had a rough start since, hope you find the cause and get it all fixed
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
