what to buy?
Old Dec 13, 2006 | 03:45 AM
squeak's Avatar
what to buy?
i have a 05 ss/sc and all i have right is a cai, ingalls etd, spec 3 clutch, and fidanza flywheel. i have $1500 to spend on mods. i was thinking about getting either the intense stg4 kit or gm stg 2 plus 2.8" pulley. i also want to get a header and dp. are the zzp ones any good? i am also oredering some cab's and engine inserts.
i dont wanna go any smaller than a 2.7" or 2.8" pulley so can someone tell me the best route to go and not spend a buttload of money?
Old Dec 13, 2006 | 09:22 AM
cobaltstg2's Avatar
if you go with the stage two kit from gm do not put a 2.8 pulley on without a tune .... it causes many problems like cracking compression rings on the piston..... just some thoughts
Old Dec 13, 2006 | 09:28 AM
crossed over's Avatar
just make sure you put some money on the side for your new axles youll need very soon.
Old Dec 13, 2006 | 09:37 AM
OZERMAN's Avatar
try to save some money for any problems you may run into. check out winnersaturnparts.com for a good price on the stage kits
Old Dec 13, 2006 | 09:40 AM
cobaltstg2's Avatar
yeah no joke on those axles and deff save some money for problems .... man have i had some hear lately
Old Dec 13, 2006 | 02:09 PM
squeak's Avatar
i dont want to change the exhaust to 3". and how are you guys with gm stg2 tuning your ecu? which kit is better for the price?
Old Dec 13, 2006 | 02:29 PM
ReMz's Avatar
u should go with tag if you want to do the gm stage II and 2.8.... depending on your altitude, u are on the verge of pushing your injectors to the limit (if no already doing so).
in all honesty, if you dont care about your warranty, just forget the GM stage kits and go aftermarket. you will see better gains and have more future tuning options.
Old Dec 13, 2006 | 02:47 PM
squeak's Avatar
of intense, tag, and ca, who has the better ecu tune? and how is everyone changing there tune with hptuner?
Old Dec 13, 2006 | 02:49 PM
Cobalt_SSTuner's Avatar
I like tags stg 2 setup. Seems like you get really good results from it.
Old Dec 13, 2006 | 03:03 PM
ReMz's Avatar
yes. they are using hptuners
i really dont kno who has the better tune. they are all reputable. tag seems to be more realistic and honest. i havent really dealt much with any of the companies tho.
Old Dec 14, 2006 | 12:58 AM
squeak's Avatar
tags stg 2 is too much for me. i dont wanna go that far with the car. i just wanna upgrade the pulley/injectors/ecu/header/dp. so im looking at tag stg1, intense stg4, and ca stg3.
Old Dec 14, 2006 | 01:13 AM
lsjwannabe's Avatar
the just go gm stg 1 2.9 pulley colder plugs and full exhaust and your good.
Old Dec 14, 2006 | 10:09 AM
squeak's Avatar
i want a around 250-260whp, but i dont wanna go into meth injection and all that stuff. i just want to do it with mods i listed
i just noticed your from macomb, you should come down to louisiana sometime. i have a friend with a srt4 that comes down fom macomb all the time.
Old Dec 14, 2006 | 10:12 AM
squeak's Avatar
hey ReMz, i noticed you are from around denver. i am sponsored by corsport in denver. they sponsor my 2004 civic si turbo. do you know of the place?
Old Dec 14, 2006 | 10:57 AM
lsjwannabe's Avatar
you do not have to go meth to get 250 you can do that by the mods i listed maybe.
Old Dec 14, 2006 | 02:43 PM
squeak's Avatar
but gm stg1 is still stock injectors, wouldnt that lean me out too much with exhaust. i mean you need more fuel for the added boost, plus more exhaust flow will lean you out
Old Dec 14, 2006 | 02:57 PM
cblt12's Avatar
no gm stg 1 is 42# injectors and a 2.9 pulley is fine... plus w/ intake and full exhaust you should be around 250
Old Dec 14, 2006 | 03:06 PM
squeak's Avatar
but how would that work? you dont need to tune for the bigger injectors? i mean the duty cycle is gonna go down unless change it in the tune. my a/f my be fine, but the ecu will still have my injectors opening too long.
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
