what does a clogged cat sound like?
Old Mar 22, 2007 | 12:26 PM
07cobaltss's Avatar
lol i know its hard to make noises in text but would it be a higher pitched type of hiss? becuase i think i may have a clogged cat, plus i'm boosting like 15 pounds at 6 grand. what are some tell tail sign yours cats going bad?
Old Mar 22, 2007 | 12:32 PM
Psykostevo's Avatar
Kinda like a meow, but with more of a garbled tone, I don't know really how to spell it, but it's pretty sad, you swear they are choking on a hairball or something.
Old Mar 22, 2007 | 12:33 PM
07cobaltss's Avatar
so then this hiss sound i'm getting isnt a clogged cat? and i know its no tthe blower, when i hear it if i put my head near my cd player sounds like i'm centered on it,and sounds like its coming from the engine bay, which to me indicates the cat... but i'm not sure. my idels is kinda sputtery but not real bad.
Old Mar 22, 2007 | 12:36 PM
arsenal21's Avatar
When my cat was clogged on my dodge ram. You can tell. My truck sounded like a vacume. There was crap for power and acceleration.
Old Mar 22, 2007 | 12:38 PM
StinkBOMB's Avatar
Check to see if you're overboosting. That's one way to tell.
Old Mar 22, 2007 | 12:39 PM
07cobaltss's Avatar
yeah like i said i'm pushing 15 pounds on stock... everything.
Old Mar 22, 2007 | 12:40 PM
StinkBOMB's Avatar
What's your vacum read at idle? This most definitely sounds like a clogged cat.
Old Mar 22, 2007 | 12:41 PM
bredick's Avatar
Damn, I was thinking of posting something sarcastic like this, beat me to it.
Old Mar 22, 2007 | 12:48 PM
Psykostevo's Avatar
Funny thing is that he didn't get it, and I think he took me seriously. Look at his reply!
You could have a Exhaust leak, but that's more of a sputtery noise. IF you ARE overboosting like you say you are, it's probably clogged, because all of the back pressure is built up. I'd get it checked, a clogged cat can be serious.
Old Mar 22, 2007 | 12:49 PM
07cobaltss's Avatar
about 15-20 hg
Old Mar 22, 2007 | 01:03 PM
ReMz's Avatar
If you have an inclination that it is clogged and you are boosting 15psi on a stock setup, your cat is most likely clogged.
Old Mar 22, 2007 | 01:04 PM
an0malous's Avatar
sounds like your pioneer tweeters are blown?
Old Mar 22, 2007 | 01:41 PM
g5mike's Avatar
I clogged my cat a few weeks ago and yes the car ran like **** to I put the stocker back on,Did you have any smoke come out the tailpipe?
Old Mar 22, 2007 | 02:20 PM
07cobaltss's Avatar
not that i know of
Old Mar 22, 2007 | 02:23 PM
NightriderCobaltSS's Avatar
What about a failing cat or Bad o2 ? are you getting any CELS ?
Old Mar 22, 2007 | 04:04 PM
95cobra68camaro's Avatar
at what temp were u making 15psi? if its like 10degrees outside my stock 07's gauge at the top of 3rd will claim 15psi, but now that its 40-45 degrees outside itll only hit the 12-12.5 like its supposed to. o yeah i do have a cai w/ stock exhaust too. I do have a sputter aswell at idle, almost like a subaru. i see 18-22 inches of vaccum at idle and in gear letting off throttle will see 25-27 inches.
Old Mar 22, 2007 | 04:35 PM
07cobaltss's Avatar
no codes at all. at here its like 60 degrees out and i'm seeing 15 psi.
Old Mar 22, 2007 | 06:10 PM
Stouffer's Avatar
Look at it after you let it run. had a cat glow orange on my gti. fn floor board was pretty dam warm to
Old Mar 22, 2007 | 06:13 PM
Darksun's Avatar
its clogged. 2 of Mined hissed too. Trust me change it. Dealer won't do it but it takes months for an actual code to throw. I'm on my 5th cat so i can tell you from all your symptoms that that cats a gonner. Its only gonna get worse and your MPGs are gonna drop.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
