what kinda power??
yeah man its going to make like 240 - 260. i pretty much almost have the same set up as you except i dont have a header and i put 240. sorry to change subject but anyone know how much boost i should be pushing? 2.8 pull im pushing 15 now
if im reading this correctly ur boosting 15psi on 2.8? im on 2.9 boosting 115kpa which is 16.6psi
our stock eaton m62 will make 250 wheel horsepower relatively easy, but past that it gets harder and harder to make power, because at 250 thats pretty much the max effiency of it past that you start running into problems with heatsoak, although im not saying that you cannot counter that heatsoak, my one friend currenty is running a 2.5 on his ion with meth, its meeeean
boost is just a measure of restriction... a freer flowing engine will produce more power at less boost. things like exhaust work, hi flow cats, headers, etc will reduce boost because the engine is working more efficiently, which lets it make more power with less work. that's why different setups will produce different boost #'s. there's too many variables involved to say x puley = y boost.
