What Plugs w/ S2 + 2.8"
Old Oct 23, 2006 | 11:53 AM
astrocrep's Avatar
I know this has been discussed before.
BUT:
I currently have the Iridiums (stock step) running w/ my S2 + 2.8". They are gapped at .40" and for the most part the car runs dynamite. I do notice though in the 2k - 3k rpms range the car sort of stutters a little bit, kinda like its building boost, but its not just a straight pull... its a little jerky. But as soon as it hits 3k, it just pulls like a bat out of hell. My friend swears by the AC Delco and going a step colder. But having paid $40 for my 4 iridiums, I am hesitant to get rid of them.
Please drop me some suggestions with support.
Thanks,
Rich
Old Oct 23, 2006 | 11:55 AM
R33P3R007's Avatar
360 L337 User
zex one step colder
Old Oct 23, 2006 | 11:56 AM
R33P3R007's Avatar
360 L337 User
CCA-82003-4 $27.39
http://store.summitracing.com/partde...view=1&N=700+0... there you go
I have 0 knock ever with these. and they werethe recomendation from Rob
Old Oct 23, 2006 | 11:58 AM
R33P3R007's Avatar
360 L337 User
or you could gap them .37 and see what happens. Do you have the updated stage 2 flash?
Old Oct 23, 2006 | 12:01 PM
DWK5150's Avatar
You like the zex plugs that much to think they are worth it?
CTCOBALTSSS's Avatar
Don't use irridium plugs. They are notorious for melting.
Get NGK BKR7E Copper spark plugs if you don't want to get the zex plugs.
The gap should be between .37 and .35!
Old Oct 23, 2006 | 12:20 PM
2K5SS/SC?'s Avatar
I hear the ZEX plugs are better than the NGK's. I'm going to give them a try as my NGK's don't like my car for some reason.
Old Oct 23, 2006 | 12:23 PM
DWK5150's Avatar
Im having troubles now that the weather is getting colder on my driver and thinking the plugs are my problem.
Old Oct 23, 2006 | 12:59 PM
astrocrep's Avatar
Originally Posted by R33P3R007
CCA-82003-4 $27.39
Those are 1 step colder then stock right?
EDIT: Also what would I notice / feel over the stock plugs.
Thanks
-Rich
Old Oct 23, 2006 | 01:05 PM
2K5SS/SC?'s Avatar
It should run smoother and pull better with the right gap. Start at .35 and work up if you need to.
Old Oct 23, 2006 | 01:11 PM
astrocrep's Avatar
What plugs are use using w/ your setup?
-Rich
Old Oct 23, 2006 | 01:23 PM
astrocrep's Avatar
Ok so when I gap and install those zex @ .35"
What am I looking for (feeling for) to know that they need to be gapped at .37"
I guess what I am saying is its hard for me to see the difference between .02" so I don't know what to expect to feel.
Thanks,
Rich
Old Oct 23, 2006 | 02:34 PM
BlilBT's Avatar
Thanks,
Rich
You Wont feel much Difference >>> But like what was said the car will be smoother thru accell!
I ran the 2.8 with stock then coppers >> Was alil Noticeable! But you have to be atuned to your car to Notice!
Old Oct 23, 2006 | 03:48 PM
2K5SS/SC?'s Avatar
Astrocrep, I have the NGK iridium gapped at .40, but they are coming out of the car when I return from my deployment. The stock plugs ran better than they do, but I think mine got fowled from a few things that were going on as well. Matty and Rob both rock the Zex plugs I guess, and it got rid of all their knock retard which smooths the car out and eliminates the bucking syndrome sometimes felt.
Old Oct 23, 2006 | 03:53 PM
R33P3R007's Avatar
360 L337 User
Thanks
-Rich
Yes, and come pre gapped since they are three prong. Rob uses them in his car and I trust his judgement. When I asked, he told me to get the zex. I have had 0 problems with them. You may notice the hesitation diassapear. but until you have something to monitor knock you never know.
Old Oct 23, 2006 | 03:54 PM
astrocrep's Avatar
I just ordered the Zexs listed in the post.
They are a step colder I assume since its what they are using. I will gap the @ .35" and let you guys know.
-Rich
Old Oct 23, 2006 | 03:56 PM
R33P3R007's Avatar
360 L337 User
-Rich
they are pre gapped. make sure not to hit mess up the gap on instal. because you need a special gapper since they have multiple diodes
Old Oct 23, 2006 | 04:07 PM
astrocrep's Avatar
Really!!
Are the pre gapped to .35??
Thanks,
Rich
Old Oct 23, 2006 | 04:11 PM
astrocrep's Avatar
BTW, you asked if I had the Stage 2 reflash, yes I do, the most current one.
Thanks,
Rich
Old Oct 23, 2006 | 04:16 PM
R33P3R007's Avatar
360 L337 User
Really!!
Thanks,
Rich
so the guy at zex told me.
Old Oct 23, 2006 | 06:23 PM
Matty's Avatar
Still running great. No knock. Runs great.
The bucking is actually due to the stage tune, HPT got rid of that.
Old Oct 23, 2006 | 07:04 PM
Gory's Avatar
Yah get the zex or bkr7e and just check the gaps but they are almost always pre gaped at .035
.035 is the best gap to run in our motors especialy considering that with boost our effective CR is about 20-1.
Old Oct 24, 2006 | 08:40 PM
astrocrep's Avatar
Ok so I installed the zex and the powerband smoothed out a bit. However, I dunno if its in my head, but I feel like I lost some power, could I have done something wrong?
-Rich
Old Oct 27, 2006 | 12:55 PM
QuikSilverSS's Avatar
I just had my Stage 2 with the Pulley Boys 2.8" 3 days ago, I used the NGK copper plugs gapped at 0.039 and it works great no hesitation or pinging, great upgrade really seems to shorten up 2nd gear, car pulls strong
Old Oct 27, 2006 | 02:18 PM
astrocrep's Avatar
Yeah, after having the Zex plugs in for a couple of days I love them!!
-Rich
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
