what is a Return Style Fuel System Kit
Old Feb 20, 2009 | 03:21 PM
bernandovelasquez's Avatar
just wanted to know what this is and what the benefits are and the requirements to install it..
thanks for your help..
Old Feb 20, 2009 | 03:25 PM
tdipowered's Avatar
lol ive been wanting to kno this too
Old Feb 20, 2009 | 03:28 PM
sounds cool and sure looks like it would look good under the hood!!
Old Feb 20, 2009 | 03:31 PM
ShortStack's Avatar
our fuel system pushes fuel to the end of the rail, and basically the fuel is pushed untill it is used... meaning that once the fuel enters the rail, it hits the end then goes into the injectors...
a return style runs the fuel through the fuel rail.. meaning that there is no end, it gets recirculated...
helps keeps pressures more constant.
Old Feb 20, 2009 | 03:34 PM
woah sounds good!! do you need a tune for it??
do you get more HP ??
Last edited by bernandovelasquez; Feb 20, 2009 at 03:34 PM. Reason: Automerged Doublepost
tdipowered's Avatar
huh sounds like a good idae if i was making big power
Old Feb 20, 2009 | 03:35 PM
ShortStack's Avatar
Yes you have to tune for it... but its simple... because your fuel pressure is set by the regulator..
It more or less lowers IDCS, so it allows for bigger power... doesnt so much gain you power.
Old Feb 20, 2009 | 03:37 PM
ahhhh.. that suck u have to get a tune for it... won't bother with it then... thanks short stack!! I should have just pmed u!! u know everything lol..
Old Feb 20, 2009 | 03:38 PM
ShortStack's Avatar
lol. Im tellin ya just save up and go turbo.
Old Feb 20, 2009 | 03:40 PM
hey quick question just for the record...
would it be just as good to buy a turbo kit for the ss s/c or it's much better to get a ss t/c ??
Old Feb 20, 2009 | 03:49 PM
ShortStack's Avatar
Personally.. yes...
the turbo on the ss/tc is small.. so if you want nice power output, youll need to look into a bigger turbo..
You can get a ss/sc used for around 11/12 k... plus 4gs for a top of the line kit, your still spending less...
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
no_ss
Oct 18, 2015 11:58 PM
