what spark plug to use???
alrite i've steped down the pully size and done an exhaust and intake and such...i also swaped out my plugs in faver of the NGK-BKR7E now with my 2.9puley do i need to go another step colder??? will it help???can it hurt any thing?
those plugs should be fine
, check them after a week or so, and see how they look, the tips should look almost like a light chocolate color, black would be bad.
Those are not the copper plugs, which you may want to consider, im actually running the same plugs as you with a 3", for almost a month, doing fine....but i dont think you need to go two steps colder for a 2.9, 1 step should be fine
, check them after a week or so, and see how they look, the tips should look almost like a light chocolate color, black would be bad.Those are not the copper plugs, which you may want to consider, im actually running the same plugs as you with a 3", for almost a month, doing fine....but i dont think you need to go two steps colder for a 2.9, 1 step should be fine
Two Trains of thought on Forced Induction and Iridium..
Iridium uses a very small annode that can withstand silly heat
Regular Spark plugs cant take unreal heat but because they are larger, they can disipate it fast.
The basic problem is that in some cases, the iridium plug gets so hot that it can actually be the cause of detonation.
so 1 step colder is gonna be fine?
i just went to autozone and told them that i need some ngk plugs for my car. i didnt get any colder ones. They are the stock number 6962 bkrge. I just needed to change them because i was getting miss firing.
that would work with stock boost levels...but not with the higher number i'm runing
Originally Posted by 06black
ok so if you were to do this...1step cloder or 2steps colder?
The whole point of running colder plugs is to reduce the risk of detonation as you increase the boost...
If GM has Plug "X" for Stock Boost. Then if you go up a bit, then one step is required.
If you plan to Silly overboost, then you go Silly ranges colder.
Stock Boost ... Stock Plugs
You don't need to go colder if the Boost han't changed.
whats this silly thing you keep speaking of?? i just want to kno what you would run with my set-up....1 step or 2 steps colder????
pulleys smaller than 3.0 = 2 steps colder.
excelent!
thank you sir
brian you think thats rite?
thank you sir
Pete's Post is acceptable.
