what spark plug to use???
Old Jan 29, 2006 | 05:23 PM
06black's Avatar
alrite i've steped down the pully size and done an exhaust and intake and such...i also swaped out my plugs in faver of the NGK-BKR7E now with my 2.9puley do i need to go another step colder??? will it help???can it hurt any thing?
Old Jan 29, 2006 | 05:28 PM
Brian MP5T's Avatar
It will not "Hurt"
Avoid Iridium Plugs. Stick to regular NGK
Old Jan 29, 2006 | 05:39 PM
silverSS's Avatar
those plugs should be fine , check them after a week or so, and see how they look, the tips should look almost like a light chocolate color, black would be bad.
Those are not the copper plugs, which you may want to consider, im actually running the same plugs as you with a 3", for almost a month, doing fine....but i dont think you need to go two steps colder for a 2.9, 1 step should be fine
Old Jan 29, 2006 | 05:40 PM
Chevypowered's Avatar
I've been thinking bout getting a step colder plugs for mine, anyone have a link to where we can get them? ZZP only has the Iridium plugs.
silverSS's Avatar
yea avoid Iridium
Old Jan 29, 2006 | 05:42 PM
silverSS's Avatar
here you go chevypowered
http://www.southfloridapulleyhq.com/...sss/ec_ngk.htm
Old Jan 29, 2006 | 05:43 PM
Thanks I just got them, for $15 why not.
Old Jan 29, 2006 | 05:47 PM
silverSS's Avatar
how do your stock plugs look?
i swapped them out right when i did the pulley swap.
Old Jan 29, 2006 | 05:48 PM
I have not taken my stock ones out yet, I haven't really thought about it since i rarley get over 12.5 psi but when i travel to a lower elevation i do so these should help.
Old Jan 29, 2006 | 05:51 PM
silverSS's Avatar
your stock plugs should be fine, but yeah its a smart idea to go one step colder..
Old Jan 29, 2006 | 08:06 PM
Brian MP5T's Avatar
Two Trains of thought on Forced Induction and Iridium..
Iridium uses a very small annode that can withstand silly heat
Regular Spark plugs cant take unreal heat but because they are larger, they can disipate it fast.
The basic problem is that in some cases, the iridium plug gets so hot that it can actually be the cause of detonation.
Old Jan 29, 2006 | 08:16 PM
06black's Avatar
so 1 step colder is gonna be fine?
Old Jan 29, 2006 | 08:25 PM
Brian MP5T's Avatar
It won't hurt with overboost.
Old Jan 30, 2006 | 12:33 AM
06black's Avatar
ok so if you were to do this...1step cloder or 2steps colder?
Old Jan 30, 2006 | 12:53 AM
GotBoost?'s Avatar
i just went to autozone and told them that i need some ngk plugs for my car. i didnt get any colder ones. They are the stock number 6962 bkrge. I just needed to change them because i was getting miss firing.
Old Jan 30, 2006 | 01:11 AM
06black's Avatar
that would work with stock boost levels...but not with the higher number i'm runing
Old Jan 30, 2006 | 07:28 AM
Brian MP5T's Avatar
The whole point of running colder plugs is to reduce the risk of detonation as you increase the boost...
If GM has Plug "X" for Stock Boost. Then if you go up a bit, then one step is required.
If you plan to Silly overboost, then you go Silly ranges colder.
Old Jan 30, 2006 | 07:29 AM
Brian MP5T's Avatar
Stock Boost ... Stock Plugs
You don't need to go colder if the Boost han't changed.
Old Jan 30, 2006 | 11:18 AM
06black's Avatar
whats this silly thing you keep speaking of?? i just want to kno what you would run with my set-up....1 step or 2 steps colder????
Old Jan 30, 2006 | 11:21 AM
p7x's Avatar
p7x
pulleys smaller than stock to 3.0 = 1 step colder
pulleys smaller than 3.0 = 2 steps colder.
Old Jan 30, 2006 | 11:26 AM
06black's Avatar
excelent!
thank you sir
brian you think thats rite?
Old Jan 30, 2006 | 12:32 PM
Brian MP5T's Avatar
excelent!
thank you sir
The Colder plugs are ment to be used a steps as the boost level increases. If you go too far, you might find on cold days that the car will not run well until it's warm.
Pete's Post is acceptable.
Old Jan 30, 2006 | 02:38 PM
p7x's Avatar
p7x
O thank you all mighty car god.
Old Jan 30, 2006 | 03:47 PM
Brian MP5T's Avatar
You coming over for movies or what BIACH?
Old Jan 30, 2006 | 04:25 PM
p7x's Avatar
p7x
no queer
