What type of meth to use
You don't want it to run out. If you're tuned right with it you can knock without it. I'm not sure, but our stock washer bottle probably has a low fluid light which is an added bonus if you use that as your resivoure. If you use another one look for one with a low fluid light sending unit and hook up a light inside your car somewhere it's easily visible. You don't want it to inject with a button. It's simplest to use when it's hooked up to something like a boost switch or map sensor. That way it'll turn on at the same psi everytime, you won't bog if it's too early, won't knock if it's too late etc. And any shop that can tune your car SHOULD be able to tune with an alcohol kit. However I would contact them first to find out for sure.
Yes you do need some kind of software to tune our cars. You will have to call around or ask on here for someone local to you who can tune. Maybe one of the members will have hpt and be able to help you out for a few bucks.
if you use the "bottle" that comes with the kits. you have no way of knowing if you ran out or not.
the factory resivoir has a low level sensor that trips the DIC, and flashes the screen. hence why i tapped that. if you use more than a gallon in a week, you need to slow down, seriously.
I am sure at that rate something metallic and car sized, or wooden and used by the phone company will slow him down.
