whats everyone use for meth injection?
Old Jan 27, 2011 | 11:35 AM
CobaltVenomSS's Avatar
yall use windshield wiper fluid?? or buy 100% meth and mix it yourself??
just seeing whats best
maybe this can be a sticky too lol
Old Jan 27, 2011 | 11:38 AM
yellowss7590's Avatar
windshield wiper fluid FTL
if you get a meth kit buy 100% meth and mix it. its not too hard and depending where you go my one friend gets it 5gallons for 50$
Old Jan 27, 2011 | 11:44 AM
Chevycobaltss3's Avatar
i bought 100% meth, and used accordingly with pulley sizes.when i had my 2.6 i did 50/50, with my stock pulley and larger pulleys like a 3.0 ect i used 100% meth
Old Jan 27, 2011 | 11:53 AM
100% meth FTW haha
Old Jan 27, 2011 | 11:55 AM
sundevil07's Avatar
I used 75/25 on my lsj mixed myself and yellowcobaltss up there youre getting ripped off on meth, vp racing out here sells it for 1.80 a gallon ten bucks is insane
Old Jan 27, 2011 | 11:56 AM
i was gonna do 75/25 on my 2.8 and if i go 2.7 prolly 60/40
yea i can get a gallon here for 3$ lol
Last edited by CobaltVenomSS; Jan 27, 2011 at 11:56 AM. Reason: Automerged Doublepost
Old Jan 27, 2011 | 11:57 AM
Godly's Avatar
I used 1 bottle of heet mixed with -20 Windshield washer fluid, its cheap!!!!!!!!!!!! haha
Old Jan 27, 2011 | 11:59 AM
i still havent installed the kit yet lol...cobalt needs other things first
Old Jan 27, 2011 | 12:02 PM
06'BlacKSS/SC's Avatar
sub'd for more info
Old Jan 27, 2011 | 12:08 PM
Black SS/SC 06's Avatar
This might help
https://www.cobaltss.net/forums/2-0l...s-here-215307/
Old Jan 27, 2011 | 12:09 PM
100% METH's Avatar
what combination of mods do you have on your cobalt?
here's a good rule of thumb when using 50/50 mixture (water,methanol)
m62 supercharger
3.1-2.8 pulley (3gph) - richens by roughly 5-6%
2.7-2.5 pulley (5-7gph) - richens by 5-10%
Old Jan 27, 2011 | 12:16 PM
m62 supercharger
im gonna use a 5 GPH nozzle and my mods are
2.8, 60's OTTP H/E Fujita CAI, ZZP shorty header with catted 3 inch downpipe and a 2.5 magnaflow exhaust along with a GMPP clutch
Old Jan 27, 2011 | 12:33 PM
Godly's Avatar
Dang dude, you've had it for months haha, which I was the same way I had the tank and pump mounted for like 3 weeks before I actually ran the lines
Old Jan 27, 2011 | 12:36 PM
im mounting it this weekend but wont run the lines till the weekend after next...
Old Jan 27, 2011 | 12:47 PM
100% METH's Avatar
Not a bad choice... I ran a 5gph w/ the 2.8 as well. On a 50/50 mixture it richens your afr by 8-10% a.k.a .8-1.0 afr
so if your running 11.8 @ wot from 3k-7k. You will richen to 11.0-10.8; lean p.e. by 8-10% or retune your maf w/ meth on to bring your afr back to your desired 11.8.
Old Jan 27, 2011 | 12:49 PM
so if your running 11.8 @ wot from 3k-7k. You will richen to 11.0-10.8; lean p.e. by 8-10% or retune your maf w/ meth on.
i cant wait!
Old Jan 27, 2011 | 02:28 PM
Leafydialupking's Avatar
Damn some of you guys and your high meth counts. I thought you started to loose power as you went over 50/50.
Old Jan 27, 2011 | 02:36 PM
383_Stroker's Avatar
The reason it's not recommended to go over 50/50 is that it becomes flammable past that point.
The reason that's an issue, is that methanol hardens most plastics and rubber compounds. So, if your pump is not one designed to be used with methanol, eventually they will start to leak through. and flammable liquid going into an electric motor is a poor plan.
That being said.. if you buy a kit from a reputable company.. it's going to be methanol safe..
Old Jan 27, 2011 | 02:40 PM
100% METH's Avatar
I'm 100% that AIS kits are designed to run on 100% methanol... For one AIS says it does, and for two I run it.
Devils Own is also capable of running 100% methanol.
moral of the story... dont buy cheap over night parts from japan... ehmm china
Old Jan 27, 2011 | 02:42 PM
100% METH's Avatar
Adding more water to the mix does yield lower hp/trq.
It's give and take; adding a greater concentration of distilled water provides greater detonation control. Water is a non-combustible fluid, virtually creating a infinite octane.
again... give and take. (also cools substantially better)
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
