Wheel hop
Old Apr 10, 2011 | 06:46 PM
Joemaster70's Avatar
Wheel hop
I bought poly Urethane mounts to be replaced with the stock ones. it's the bushings or w.e
If i were to get a solid Engine mount does that cancel the 2 Poly trans mounts?
Old Apr 10, 2011 | 06:50 PM
conerboner's Avatar
no they work together to prevent wheel hop but the rotated trans mounts are better...
Old Apr 10, 2011 | 11:02 PM
better cause they don't vibrate the engine? How much better could they be cause 50$ for 2 poly mounts seems reasonable for some drivetrain help, Rotated mounts are 150+ a piece. I think they do the same
Old Apr 11, 2011 | 05:38 AM
Jdam8139's Avatar
I don't have the rotated mounts yet, but IIRC they actually rotate the powertrain to align with the axles better (hence the name). The poly inserts would just reduce or cancel the "play" allowed by the stock mounts...
Old Apr 11, 2011 | 06:50 PM
D_Rob's Avatar
I spoke on the phone with Josh @ OTTP just last week about this. The rotated mounts have stiffer than stock bushings, but nothing as hard core as poly. They should tighten up the engine a bit and most importantly fix the drive line geometry that gives us wheel hop.
He said 90% of people just get the front mount and the spacer which is cheap and you can always buy the rear mount later if you want.
Old Apr 12, 2011 | 09:28 PM
ah nice info
Old Apr 13, 2011 | 06:50 AM
06cobalt racer's Avatar
i have the poly inserts and a ttr engine mount. NO wheel hop at all and there are barely any vibes
Old Apr 13, 2011 | 06:55 AM
BlueSS/SC's Avatar
Powell mounts FTW!
I get no wheel hop at the track with these babies
Old Apr 13, 2011 | 12:14 PM
TurboTechRacing's Avatar
Yes having all the mounts is always the best.
As you sated no, to little vibs compared to stock Plus for a few vibs, you really get to feel how the car is holding and it gives you feed back when you are pushing it. Plus NO wheel hop is great!
Old Apr 13, 2011 | 12:22 PM
Brags's Avatar
When I had all polys and solid engine mount, no wheel hop but car shaking to pieces lol. Now have rotated mounts and stock engine mount, no wheel hop no shaking.
Old Apr 13, 2011 | 12:32 PM
michiganfootball911's Avatar
So you replaced your aftermarket engine mount (TTR?) with the old stock one and the poly trans mounts with just the new rotated mounts?
I have the same set up with the TTR engine mount and the poly bushings, you are right about the car shaking to pieces.
I would love to get rid of that bullshit noise... but still want no wheel hop, and the feel of the engine power
Old Apr 13, 2011 | 12:36 PM
Brags's Avatar
Yes I did, now I have front rotated mount, rear lnf mount with spacer, and stock top mount. No vibes, no wheel hop 320 whp on a 2.2
Old Apr 13, 2011 | 12:42 PM
ericgt79's Avatar
i got them both and i got a few vibes when i installed but they settled in nicely then i got the rear sway bar and they completely went away...turn your ac on and all bets are off.
just dont get them from Aaron he sucks donkey *****
Old Apr 13, 2011 | 12:44 PM
LOL, thanks Eric
Old Apr 14, 2011 | 12:54 PM
microgab's Avatar
Alright, so i saved enough money. If i want the best bang for the buck, which set of mounts I should get? ZZP? ottp? Any links? I have a 2.9" stage 3 but planning to get lot more mods thanks!
Old Apr 14, 2011 | 01:03 PM
rhanes216213's Avatar
I just purchased the complete mount set from TTR for $200.00. Got them via FedEx Ground. They were on sales.
Old Apr 14, 2011 | 01:05 PM
Yup no waiting, and a great price for a complete set of mounts!
Old Apr 14, 2011 | 09:18 PM
microgab's Avatar
And it terms of performance, do they eliminate 100% wheelhop?
Old Apr 14, 2011 | 09:21 PM
No mount will ever do 100%, you would be fooling yourself. There are many other variables involved. They will reduce as much as the mounts will allow them to.
Old Apr 14, 2011 | 11:23 PM
whats best Solid Engine mount or Trans mounts?
Old Apr 15, 2011 | 06:16 AM
Here you got:
https://www.cobaltss.net/forums/supp...others-247902/
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
