Wheel-Hop Kit 19211782
Subscribe
Dec 4, 2011 | 08:52 PM
Is this an upgrade to the LSJ? Just looking to upgrade my balt and minimize wheel hop.
http://www.crateenginedepot.com/stor...Kits-C250.aspx
Thanks
Jose
Reply 0
Dec 4, 2011 | 08:55 PM
Save your money
ZZPerformance - Rotated Front Trans Mount #05-02-00985-R2
ZZPerformance - Rotated Rear Trans Mount #05-02-00986-R2
Reply 0
Dec 4, 2011 | 08:56 PM
I'd save ur money and just get some rotated motor mounts from powel, zzp, ottp or TTR, take ur pick really there all good, i got TTR's and i got no wheel hop what so ever
Reply 0
Dec 4, 2011 | 09:12 PM
Just buy the lnf mounts 40 bucks each...
Reply 0
Dec 5, 2011 | 10:49 AM
Quote: Just buy the lnf mounts 40 bucks each...
bingo and get the spherical cabs to go with them you wont be dissapointed
Reply 0
Dec 5, 2011 | 02:19 PM
I agree to the mounts from zzp, powell, ottp etc if you can.
Axles will eff your tranny
Reply 0
Dec 5, 2011 | 04:03 PM
axels wont hurt the transmission
Reply 0
Dec 5, 2011 | 04:39 PM
stronger axles can in fact hurt the trans because the shock from launching has to go somewhere, thats why most people rather have weak axles b/c they are easy to replace and fairly cheap
Reply 0
Dec 5, 2011 | 07:50 PM
jose,
you can do the axel convertion as angel did, he convert the lnf axels and breaks to the lsj
if you want to more info you can pm and i will gave you him phone nuber
also some rotated mounts helps a lot, if you install them right.
Reply 0
Dec 5, 2011 | 08:45 PM
I appreciate all the suggestions and comments but I still looking for an answer. Is this kit in fact an upgrade to the LSJ?
Gabi,
Send me the phone number. Gracias
Reply 0
Dec 5, 2011 | 09:16 PM
^ Yes it is. But there are better options. This is overpriced.
Reply 0
Dec 5, 2011 | 09:51 PM
Got it, thanks. Yeah it seems overpriced and definitely looking for zzp items.
Thanks all
Jose
Reply 0
Dec 5, 2011 | 10:51 PM
Quote: stronger axles can in fact hurt the trans because the shock from launching has to go somewhere, thats why most people rather have weak axles b/c they are easy to replace and fairly cheap
more people have broken transmissions on stock axels then aftermarket
Quote: Got it, thanks. Yeah it seems overpriced and definitely looking for zzp items.
Thanks all
Jose
get the lnf mounts they are rotated like the ottp and zzp and ttr and alot cheaper in price to boot i would also get a set of spherical cabs for the a arms some of the wheel hop comes from the stock a arm bushing flexing and binding up the a arm when loaded from a launch
Reply 0
Dec 5, 2011 | 11:40 PM
Quote: get the lnf mounts they are rotated like the ottp and zzp and ttr and alot cheaper in price to boot i would also get a set of spherical cabs for the a arms some of the wheel hop comes from the stock a arm bushing flexing and binding up the a arm when loaded from a launch
i didn't know LNF mounts are rotated.....
Reply 0
Dec 6, 2011 | 05:39 AM
Quote: i didn't know LNF mounts are rotated.....
There not last time i checked
Reply 0
Dec 6, 2011 | 07:09 AM
They aren't.
They are much stiffer than the LSJ trans mounts though, and are a decent upgrade.
I have the Powel Stage 1 rotated mount, and GMPP (LNF) rear trans mount.
Works great!
Reply 0
Dec 6, 2011 | 08:11 AM
Works great!
I was about to say a lot of people are wasting money on rotated mounts if the LNF comes with them lol.
Reply 0
Dec 6, 2011 | 09:47 AM
LNF mounts have stiffer inserts than LSJ. NOT rotated.
Reply 0
Dec 6, 2011 | 09:59 AM
Looks like someone dont know as much as they think they do 😱
Reply 0
Dec 6, 2011 | 10:20 AM
the lnf mounts i got from ced did rotate the engine probably not as much as others but it did move
Reply 0
Dec 6, 2011 | 10:22 AM
Quote: the lnf mounts i got from ced did rotate the engine probably not as much as others but it did move
More than likely due to the stiffer bushing.
I noticed this as well when all I had were the GMPP trans mounts.
Reply 0
Dec 6, 2011 | 10:37 AM
It most likely did however if the lnf came with rotated mounts they wouldn't make aftermarket ones because it wouldn't accomplish anything.
Reply 0
Dec 7, 2011 | 12:11 AM
i chose the lnf mounts to keep the factory look in case i need any warranty work done. they have worked out pretty well.
Reply 0
Dec 7, 2011 | 12:19 AM
I have some ttr rotated mounts for sale if youre looking for some rotated mounts.
Reply 0
Dec 7, 2011 | 10:44 AM
correct.
Reply 0
