Wheel Hop Solutions
Old Jun 20, 2007 | 04:08 PM
RedlineBrian's Avatar
Remove foot from gas pedal.
Old Jun 20, 2007 | 04:18 PM
Omega_5's Avatar
Well, by now everyone has posted up the sure solutions, so I might as well follow suit and list it for you!
Mechanical -> Ingalls or solid mounts, poly tranny mounts, poly control arm mounts, traction bars
ECU -> limit boost in lower gears
Either way, the best solution and best mod you'll ever do is.... DRIVER MOD 2.0
Old Jun 20, 2007 | 04:21 PM
TurboTechRacing's Avatar
The Turbo Tech Racing upper mount and the Prothane trans bushings after about 500 miles vibrant no more than the Ingalls. However you wont have to worry about bent brackets with a replacement engine mount, as the Ingalls has had some issues with.
Old Jun 20, 2007 | 11:10 PM
Master Shake's Avatar
can anyone verify the part number for the ingalls
Old Jun 20, 2007 | 11:23 PM
redrocket's Avatar
Just about everyone carries the Ingals. The 05-06 listed part will fit and work just fine on an 07(I have both an 05 & 07). I have mine set at 12MM and get a little more vibration than at 15MM, however wheel hop is gone (street and track).
Old Jun 20, 2007 | 11:27 PM
hawlyns711's Avatar
i put in my ingalls today and took it for a good test run. i couldnt really get any wheel hop, i just usually get it at the track, but i'll have to wait to find out. some new vibrations at idle and launch in 1st, nothing to get a headache over. plus wheel-hop = traction
Old Jun 21, 2007 | 12:05 AM
Here is a link to the Turbo Tech Racing Mount:
http://www.turbotechracing.com/produ...idproduct=4933
Here is a link to the Ingalls:
http://www.turbotechracing.com/produ...idproduct=4591
Old Jun 21, 2007 | 12:12 AM
silversccoupe's Avatar
Thought I'd throw in my two cents.You have two opyions the way I see it.You can build a great street car and live with its shortcomings at the race track.....or.....you can build a graet race car and live with its shortcomings on the street.
Old Jun 21, 2007 | 01:19 PM
will this fit the supercharged models?
http://store.summitracing.com/partde...5&autoview=sku
Old Jun 21, 2007 | 01:24 PM
Yes that is it, however you should purchase it from a supporting vendor on this site, as we help make these forums possible.
We carry them at the same price. www.TurboTechRacing.com
Old Jun 21, 2007 | 01:32 PM
  #36
Area47's Avatar
Rent me! per hour
i have the TTR mount in my car. vibration is noticeable. rear view jumps all over about 1300 rpms, but im willing to sacrafice that for saving my tranny. it does change the tone of the motor, and there will be more vibrations. you will get used to it.
function over form
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
MrInsanityWolf
Sep 29, 2015 04:54 PM
metroplex
Sep 27, 2015 07:48 AM
