where is it?
damn...my pedals are dirty
OP thinks that the switch will solve his problem of riding the clutch. which it will not fix.
Last edited by EXsoccer1921; Jan 6, 2009 at 02:57 AM. Reason: Automerged Doublepost
Also dont mind the noobs around here. If it isnt a thread about intake pipes or cutting off your muffler, they will flame what they dont understand.
i have a similar issue but there are 2 switches one as u press the clutch and another as you let it go when the cluch pedal is let go completetly it hits another switch up top im not crazy im sure of this it broke when i was shifting like a maniac and pop my clutch alot . my cruise dosent work and my wot box isnt either so im thinking of changing both pretty cheap i seen one for about 4 bucks
yea it is white plastic just screw it upward so it isnt as close to your clutch pedal...i had mine replaced by the dealer because my cruise control wouldnt work. then it started acting pu again and i just adjusted it and it is perfecttttttttttttt
There are 2 switches on the clutch pedal. The one I posted is part of the pedal assembly. Its called the CPP switch and its the one used for cruise control. The white one at the bottom is for starting, its called the CSS switch.
