Where to get 2.9" for Stage 2 hub?
Old May 14, 2007 | 01:15 PM
ssilver's Avatar
Where can I get a 2.9 inch pulley that will fit the stage 2 hub?
Let me makes sure I understand this correctly.. The stage 2 pulley mounts different than the stocker. If a pulley fits the S2 hub, all I have to do is pop the bolts off and plop it on right? No pulley puller needed in this situation? Right? *shrug*
Also, How much difference did you guys notice that are running 2.9 on stage 2 vs. stage 2 pulley? I've never really seen and dyno or track comparisons. My guess is maybe 10hp or less and just barely noticeable... Or is it like "Holy crap Batman!"... I'm hoping for the batman part..
I'm sure this info is on here somewhere already. But I don't feel like going on an hour long scavenger hunt picking through crap I've probably already seen before just to have more questions. Sorry If you get mad.
Old May 14, 2007 | 01:36 PM
06_SS_S/C's Avatar
Yes, you just have to remove the bolts and swap the pulley over. The hub stays on the supercharger. There is a guy on here who makes them. He can make whatever size you want that bolts onto the stage2 hub. Here is the link to his ebay auction where he sells them.
http://cgi.ebay.com/ebaymotors/Chevy...spagenameZWD1V
Old May 14, 2007 | 01:38 PM
Red2.4SS/SC's Avatar
Also, How much difference did you guys notice that are running 2.9 on stage 2? I've never really seen and dyno or track comparisons to the Stage2. My guess is maybe 10hp or less and just barely noticeable... Or is it like "Holy crap Batman!"... I'm hoping for the batman part..
you need to contact nate herbstrt or somthing like that he makes custom pulleys to fit your needs
Old May 14, 2007 | 01:42 PM
Herndon_High_SS's Avatar
WHAT!? No pulley puller once you get stage 2? That's awseome if its true.
Old May 14, 2007 | 01:44 PM
beercan's Avatar
its true .. why else would your pulley be mounted on a hub?
Old May 14, 2007 | 01:57 PM
RaineMan's Avatar
That's really the only reason to get Stage 2... if it didn't have the quick-change hub you'd be better off buying everything seperately and getting a custom tune.
Old May 14, 2007 | 01:59 PM
portergraph's Avatar
yep, nherbst454 will hook you up...
CobaltPerformanceParts's Avatar
http://www.cobaltperformanceparts.co...roducts_id=336
Old May 14, 2007 | 02:02 PM
chevysalesman614's Avatar
ZZP has a quick change hub also..
you can get a pulley like that right here:
http://www.zzperformance.com/cobalt_...cts.php?id=142
IDK about the batman stuff. But, I'm running with a 2.9" pulley and CAI, + catback... My times are listed in signature..
Last edited by chevysalesman614; May 14, 2007 at 02:04 PM. Reason: Automerged Doublepost
Old May 14, 2007 | 02:14 PM
chipsgt's Avatar
If anyone knows, how was the differance between Ste stage 2 pulley and the 2.9?
Big enough of a differance to make this worth while?
Meaning, could you FEEL a differance?
Old May 14, 2007 | 02:33 PM
you're gonna pick up like 2psi under perfect conditions... but it will get to max boost faster.
i think it would be around 8-12WHP.. and like 15-18WTQ. Probably noticeable. but the pulley is only $60USD.. so what do you have to lose?
Old May 14, 2007 | 02:35 PM
ssilver's Avatar
Thanks guys.
I will know in probably a week and will let you know.
Old May 14, 2007 | 02:36 PM
Acidangel_5.0's Avatar
nherb... excellent work on the pullies..
Old May 14, 2007 | 02:45 PM
CTCOBALTSSS's Avatar
Couldn't have said it better myself. It works nicely.
Old May 14, 2007 | 02:48 PM
06blackSC's Avatar
I can vouch for Nate's (nherbst454) pullies. I have his 2.9 high polished for the stage 2 hub. fitment was perfect and its light as hell to boot. excellent quality over all. I could feel a slight but noticeable difference in the car with the pulley. I installed a fujita CAI, this pulley and zex plugs all at the same time. It was a really nice worth while upgrade.
Old May 14, 2007 | 02:58 PM
there all light as hell
Old May 14, 2007 | 03:22 PM
would being a light wheight pulley make it more efficent and in turn making boost faster?
Old May 14, 2007 | 04:35 PM
ssilver's Avatar
It shouldn't make a difference.. Maybe if you were comparing a 50lb pulley to a 4oz pulley. Then weight might be and issue.
Old May 14, 2007 | 04:38 PM
Try2k's Avatar
A lighter pulley will boost faster
Old May 14, 2007 | 05:09 PM
ssilver's Avatar
Maybe I'm wrong then. But you wouldn't think the engine would spin the supercharger any faster over a few .oz's. Friction, pulley diameter, and supercharger construction would overplay weight.
Old May 14, 2007 | 07:07 PM
ecotecon18s's Avatar
well think about it...the same goes for wheels on a car...same size 18" wheel and tire but one weighs a couple pounds less...there will be a difference...
Old May 14, 2007 | 07:14 PM
ssilver's Avatar
Yeah it makes logical sence.. but.. I would still like to see what difference a pulley 4oz's lighter than another one would do.
Old May 14, 2007 | 07:45 PM
Stouffer's Avatar
Got mine form cobalt performance. great product, fast shipping, bolts right on
Old May 14, 2007 | 08:19 PM
Mikey851's Avatar
It makes enough of a difference that if you had the choice between two pulleys and one was 4oz's lighter, you should take the lighter pulley. It won't be all that noticeable but it helps create boost a little faster when you need it.
Edit: Oh BTW, it's not a 4oz. difference, it's a 12oz difference. You could actually probably log the difference if you wanted to waste the time.
Old May 14, 2007 | 10:26 PM
bojan's Avatar
stock pulley factory is = 3.75'?
Stage 2 pulley is 3.00'?
plz A
HEATON
Oct 16, 2015 07:21 PM
Sep 30, 2015 07:22 AM
cw383
Sep 30, 2015 12:41 AM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
