Where to get Stage II tuned/installed?
Obviously the Dealership is the only choice I know of right now... but is there something better? I am in PA, what do you guys recommend?
I recommend reading up and installing it yourself, then driving to the dealership *taking it very easy* and having them flash the tune on
Or if you want I will be coming out to the east coast soon, I could install it for you and then give you a proper tune.
.Or if you want I will be coming out to the east coast soon, I could install it for you and then give you a proper tune.
I had given thought to installing it myself, but the tuning process is what I am concerned about. How much do you think the dealer charges for the reflash of the ECU? and how much would you charge?
well if you came down to where i work in md its like 2 1/2 hrs away from you and we could install it and the use the gm tune for you i would do it for 100 and thats install and tune you have the paper work correct
What paperwork? I just bought the kit off of a member here...
Yeah maybe, but I am done with the other threads so I guess this will be the one.
Anyway I don't need an ECU flash from GM if I get someone else to tune it after the stage II is put on, is that correct?
even the tune file number because that is the only way to get the tune from gm is to have that part number and the little paper work that came with the kit do you kinda understand what i mean
