Where to put sender for water temp gauge
Old 04-03-2007, 08:42 PM
06_SS_S/C's Avatar
Hello,
Just wondering if anyone has installed an electronic water temp gauge in the 2.0L and where the put the sending unit? Or can the stock water temp gauge sender be tapped into? Any help would be appreciated.
Thanks!
Old 04-03-2007, 08:49 PM
RaineMan's Avatar
What's wrong with the stock coolant temp readout? I keep my DIC set on that constantly.
Old 04-03-2007, 08:53 PM
06_SS_S/C's Avatar
I am weird always want to see the outside temp. Plus I prefer to have an analog gauge to look at out of the corner of my eye. It's a lot easier to see the position of the needle then having to keep reading the DIC.
Old 04-03-2007, 09:01 PM
RaineMan's Avatar
Hmm... well... get over your addiction to the outside temp... put the window down... you'll know if its hot or cold immediately LOL. Seriously... I dunno anything about wiring a gauge.
Old 04-03-2007, 09:07 PM
Yellowbalt's Avatar
The factory sender is right at the return to the radiator, NOT at the thermostat. I am fabbing an in line tube int the hose, drilled and tapped to take a sender (mechanical) in my case, as there is always some flow through the hose, it should see within a few degrees of cylinder head water temp.
Cheers
Richard
Old 04-03-2007, 09:18 PM
06_SS_S/C's Avatar
Cheers
Richard
Do you know if the factory sender will work with an aftermarket (Autometer) gauge?
Old 04-03-2007, 09:38 PM
I'm old school
Halfcent's Avatar
The red ones are oil. The only one left on the lower right is water. You can install a sender there.
Old 04-03-2007, 10:19 PM
06_SS_S/C's Avatar
I saw those pics in another thread, but everyone was saying that wasn't for the 2.0, just for the other motors?
I'll go take a peek and see if I can see those.
Hmm I looked everywhere (i think) and didn't see anything like those plugs. Where exactly is that supposed to be?
Old 04-03-2007, 11:01 PM
climber55's Avatar
I've been wondering the same thing. I like mechanical gauges and need sender locations too.
Old 04-03-2007, 11:07 PM
I'm old school
Halfcent's Avatar
That is a picture of the trans side of an L61 head. The freeze plugs should be the exact same on the LSJ head. That's my picture.
Old 04-03-2007, 11:10 PM
Yellowbalt's Avatar
The cylinder head pics are for the L61. The cylinder head on the LSJ is very dissimilar (Alldatadiy.com). The back of the LSJ head is covered with the cam position sensor etc, the plugs are not there. I will be teeing off the oil pressure port (above the starter) for the oil pressure, M12X1.75 thread, and will be using a radiator hose adapter for the temp. You cannot tee into the factory temp sender for an electrical gauge, the resistance across the input of the electrical gauge will adversely affect the voltage the computer will see, and will alter what the computer sees.
Hope this helps
Cheers
Richard
Old 04-04-2007, 12:27 AM
06_SS_S/C's Avatar
Hope this helps
Cheers
Richard
Thanks for the info. I did some browsing and came across this on autometers website...
http://www.autometer.com/cat_accesso...il.aspx?vid=52
We do have a 1.5" radiator hose, correct? If so, I will just use this and get it as close as I can to the head and hopefully the reading will be pretty close.
Old 04-04-2007, 10:38 AM
06_SS_S/C's Avatar
Anyone know the size of our radiator hose?
Supercharged06SS
12-11-2022 04:47 PM
06MetallicBalt
08-17-2021 03:40 PM
Sl0wbaltSS
11-21-2018 11:11 PM
Stuff
10-01-2015 05:47 PM
z28addiction
09-28-2015 12:03 AM
Quick Reply: Where to put sender for water temp gauge
