Who makes AC delete pulleys?
Old 12-04-2012, 02:57 PM
Stumpalump's Avatar
Local parts stores can't find an AC delete pulley and I have had no luck online. Has anybody seen one or have a source?
Old 12-04-2012, 03:03 PM
1AJeremyD's Avatar
Dorman products is the only one that makes them from what I know of but I don't think they have them available for the cobalts yet.
Old 12-04-2012, 03:04 PM
Ryguy_stage2_SS's Avatar
pretty simple, gut the ac compressor, now you have what you want.
Old 12-04-2012, 03:42 PM
Stumpalump's Avatar
I'd need a clutch puller to gut it so I was hoping for an easy to install a pulley kit. Then I could pass on the good compressor to somebody that needs one.
Old 12-04-2012, 04:23 PM
Powell Race Parts's Avatar
No you dont need any pullers. Just unbolt the back end of it and stick the front pulley with its mounting housing by itself, back on. end of thread.
Old 12-04-2012, 04:27 PM
startingline05's Avatar
I really like having my ac. Why would you want to get rid of it?
Old 12-04-2012, 04:49 PM
lol me too bitd the racers were like " no chrome/no hubcaps/no ac/ just maxpower"
Old 12-04-2012, 06:42 PM
mrbelvedere's Avatar
sand rail
Old 12-04-2012, 06:56 PM
^^^ur so smart lol....
Old 12-04-2012, 06:58 PM
Stumpalump's Avatar
I saw what looks like the thru bolts behind the pulley. I have to look at the back end again. Hopefully it will pop apart easy.
Yea it's in a rail and that extra few pounds hanging off the rear end is not needed.
Old 12-04-2012, 07:18 PM
LS6Rally's Avatar
i have wondered what did they do for a pulley delete on the XFE's? or are the 2.2's set up that they can use a different belt and routing?
Old 08-25-2013, 11:59 AM
Stumpalump's Avatar
Bump. Still searching. Looking for any leads and will offer up a good compressor and clutch for free!
Old 08-25-2013, 12:14 PM
South Central *********
JapEatr's Avatar
Run a smaller belt
Old 08-25-2013, 12:18 PM
hucks1987's Avatar
yea, why wouldnt you just run a smaller belt and take it all off?? Or am i missing something here?
Old 08-25-2013, 12:35 PM
Stumpalump's Avatar
It needs a lower pulley so the belt coming off of the S/C has a path.
Old 08-25-2013, 12:45 PM
john powell told you how to do it
Old 08-25-2013, 01:19 PM
Stumpalump's Avatar
My compressor bolts together from under the pulley not from the back like he referred too. None of the A/C clutch pullers I have fit and don't know of one is even made considering most swap the whole compressor unit. I have the outer clutch plate off and will grind it apart to reuse the hub but the pulley is kicking my ****.
Old 08-25-2013, 03:11 PM
This is an LSJ thread. If you have an LSJ then you have been told what to do. Of you say your ac compressor is different you either don't have an LSJ or you have the wrong ac compressor. As the LSJ is supercharged you hardly have a different ac compressor as you need an eight rib pulley. So. Sounds like you are confused
Old 08-25-2013, 04:22 PM
Stumpalump's Avatar
Confusion is certainly not out of the question.
Old 08-25-2013, 06:37 PM
Stumpalump's Avatar
It's done! The compressor went from 12lbs to 6lbs and its a free mod. 3 bolts hold the compressor on and a torks bit holds on the clutch steel plate. A snap ring holds on the pulley but I needed a little persuasion with a regular two prong puller to slide it off. A couple of screwdrivers would have worked. Another snap ring holds on the electro magnet and then the six bolts holding the case together are exposed. Once those are out it pops right open and the guts fall right out. A snap ring and bolt held on two more unused parts and that's it. It goes back together in moments and is back on with the three bolts. Thanks to Powell for the solution I was looking for! 05 Cobalt SS S/C with Delphi compressor.
Supercharged06SS
12-11-2022 04:47 PM
10-20-2015 09:56 PM
dennis69
10-20-2015 04:49 PM
SSLOW06
10-01-2015 07:21 PM
patooyee
10-01-2015 01:07 PM
Quick Reply: Who makes AC delete pulleys?
