Why #4?
Old May 28, 2007 | 08:51 PM
FryLoch's Avatar
Why #4?
Why do I always hear about the forth piston blowing?
Old May 28, 2007 | 08:52 PM
widebody_balt_ss's Avatar
from what i understand its the furthest from our weak fuel delivery system and leans out b/c the car cand deliver enough fuel to it- of course i could be totaly wrong and get owned here in a min or two.... guess we will find out!
Old May 28, 2007 | 08:54 PM
DaREDss's Avatar
if your wrong atleast you sound smart
Old May 28, 2007 | 08:57 PM
lol, it works if i do it in an area where no one else is around.... i dubt it works here..
i have to be good at it. im a car salesman. lol.
Old May 28, 2007 | 08:59 PM
mastashake4u's Avatar
I think i read somewhere because it is the hardest working piston
although im not sure - thats just what i have heard
Old May 28, 2007 | 09:01 PM
... ummm you could have atleast added something to suport your thery like i did,... lol
Old May 28, 2007 | 09:02 PM
yea im looking dude lol
plus like i said its not my thery
its just something i read on this site
Old May 28, 2007 | 09:10 PM
CJ BadBlackSS's Avatar
We have a returnless fuel system so #4 is the last in the line. Problem is that when people are running 60# injectors the fuel rail can't supply enough to the #4 injector since its last in line and BOOM
Old May 28, 2007 | 09:14 PM
Area47's Avatar
Rent me! per hour
number fails because of heat. pure and simple. not detonation.
it is a widely known fact that the last injector on the fuel rail is 99% running a lot hotter, it gets less fuel then any other cylinder.
this applies to dsm's, honda's, ls1's whatever it may be.
one of two things are happening here. people running way to lean, not enough timing {low timing increases cylinder temps greatly} or just not paying attention to what the car is telling you.
if you're running anything under the 3.0 pulley, or have a crazy ass tune in the car. you NEED an egt. some might say. "well my a/f ratio was spot on, no KR. but it still blew up"
well, what were the cylinder temps????
ah ha, catch 22 kiddies.
there ya go in a nut shell
Old May 28, 2007 | 09:18 PM
quick q: not to steal the thred but what the best way to cool cylinder temps? meth im guessing?
Old May 28, 2007 | 09:26 PM
IMADreamer's Avatar
Meth will help as well as a second heat exchanger but the real problem with the SS/SC is that when running those super small pulleys (2.6, 2.5) is that the supercharger is spinning way past the point of peak efficiency meaning that it is making far more eat them it is worth for the amount of air it is moving. So the real solution to more power without burning up a cylinder is to swap the power adder out to a twin screw or turbo. Something that can move more air without creating as much heat.
Old May 28, 2007 | 09:31 PM
cybcow's Avatar
^This is exactly the problem. I'm waiting for my new engine as we speak.
Old May 28, 2007 | 09:38 PM
patathSS's Avatar
Would a return style fuel system help even things out?
Old May 28, 2007 | 09:42 PM
yes! i am trying to peice together everything i need to do this right now.
Thats the theory along with adding another fuel pump to up the line pressure.
Old May 28, 2007 | 09:44 PM
Area47's Avatar
Rent me! per hour
could, or a new style fuel rail, or a split rail. either one. could work better.
the blower is fine. what people are trying to do is band aid the power making process on these engines.
why is it, a k series rsx with the m62 can put down 280+ whp on 9 psi.
where as it takes us over 17 psi to do that. or nitrous.
same general design in the engine catagory.
heads? yep, ours flows like a napkin.
cams? power to be had, if done right.
water injection will help. i dropped 20 degrees in temps by dumping the coolant out of the h/e and putting in purifed/ bottles water.
Old May 28, 2007 | 09:46 PM
Coblt ss super's Avatar
i heard it was something to do with the cooling of cylinder 4 thats why it always goes
Old May 28, 2007 | 10:35 PM
Halfcent's Avatar
I'm old school
I completely disagree.
The LAWS of physics are on my side. Fluid dynamics demand that pressure in a closed liquid system is constant throughout the entire system. It means absolutely nothing that there are 4 injectors on the rail. If those 4 outlets cause so much flow that pressure actually does drop, then it drops evenly through the entire system, all the way back to the tank.
I actually have two alternate theories.
First, there are two ways for mixture to go lean. First is not enough gas. Second, and much more likely, is too much air. It is very possible the design of the blower outlet attached to the laminov tends to favor the #4 runner. And that is a gaseous system, so the air is most definitely compressable. I bet the inlet pressure at #4 is a bit higher then the rest.
Second, our engine cooling system favors the #1 side. Freshly cooled coolant enters the cylinder head right above the #1 cylinder, then flows across the block. By the time it gets to #4, it's as hot as its ever going to be before exiting the engine at the thermostat.
Old May 28, 2007 | 10:52 PM
yeah i agree with the cooling as i mentioned before, i think Cameron(Blown-4-Banger) had mentioned that to me before, how can we like fix that?
Old May 28, 2007 | 11:00 PM
Area47's Avatar
Rent me! per hour
this all leads back to excessive cylinder temps.
Old May 28, 2007 | 11:08 PM
c24na's Avatar
mmm.. good read. Thats y i picked up an autometer cobalt series EGT gauge and fuel pressure gauge. When I get a chance to pull of the manifold, we'll see whats really going on.
Anybody have an extra fuel rail for sale? Once i see if theres any fp drop, or not, i want to take the fp gauge out.
THanks,
Nate
Old May 28, 2007 | 11:33 PM
IMADreamer's Avatar
You can not compare hp and PSI figures from two different engines even if they use the same blower because there are a lot of x factors.
The fact is that guys using the really small pulleys are causing the SC to make more heat then it's worth. With a 2.5 pulley you are using meth, a second HE, dual pass IC and the oversized injectors to cool the cylinders down because the heat is too much. Number 4 fails because of a variety of reason all related to the build up of heat. You can partly put the blame on the fuel system but it all boils down to heat. Running a more efficient compressor would go a long way to solve this problem.
Old May 29, 2007 | 12:06 AM
NJHK's Avatar
1. K series engines rev much higher
2. They have higher flowing cylinder heads
3. Look at how much torque they produce
4. Look at where their max hp is at
You're basically comparing apples and oranges.
Old May 29, 2007 | 12:12 AM
shabodah's Avatar
One thing people are leaving out of the equation is the location of the thermostat.
Old May 29, 2007 | 12:13 AM
boostbalt's Avatar
Don't K series also run at much higher stock compression? I think he was talking about a M62 on a stock K series?
