Wich Coolant is the Best one?/
Old Jun 6, 2009 | 05:36 PM
ssua's Avatar
Hi everyone. My radiator had a leakage and now I bought a full radiator setup. My question right now for you guys is: Witch Coolant will be the best one for the radiator and also for the Intercooler. plz let me know
Thanx
Old Jun 6, 2009 | 05:39 PM
boostedss26's Avatar
use the search button. Dexcool
Old Jun 6, 2009 | 05:59 PM
ssua's Avatar
alright man thx
Old Jun 6, 2009 | 06:36 PM
wilson79's Avatar
Use Decool only. It is the only approved coolant for GM.
Old Jun 7, 2009 | 01:16 AM
krazycobalt's Avatar
Dexcool!!!
Old Jun 7, 2009 | 01:22 AM
Maven's Avatar
Evans NPG+
Old Jun 7, 2009 | 01:25 AM
OneCOLDBIZL272's Avatar
you can use the green stuff, but only if had your motor clean out during say a rebuild and it was hot tanked and cleaned out other wise i would stick to the dexcool, but i been running the green stuff on my gms for so sometime i dont have any problems. i dont care for dexcool, but thats only my opinion, in your case just stick with the dexcool
Old Jun 7, 2009 | 10:23 AM
Josh@ottp's Avatar
Originally Posted by Maven
Evans NPG+
I second this.
Old Jun 7, 2009 | 10:24 AM
damien's Avatar
Water, technically
Old Jun 7, 2009 | 11:13 AM
ssua's Avatar
at the moment I'm not really sure witch one to use.
So you guys are telling me that the best thing that I can do is to use the same coolant for both the radiator and the intercooler?
Old Jun 7, 2009 | 11:20 AM
aterminatorz's Avatar
Originally Posted by damien
Water, technically
Won't plain water cause the system to rust over time? Water will freeze in the winter, so it won't work if you live in a cold climate. To the OP, just stick with the DEXCOOL. Mobil 1 for your engine oil.
Old Jun 7, 2009 | 11:22 AM
joeworkstoohard's Avatar
personally, i thnk dexcool is okay, but you need to change it pretty often.
Old Jun 7, 2009 | 12:30 PM
damien's Avatar
Distilled water, and correct it won't work if you live where it gets cold.
Old Jun 7, 2009 | 02:01 PM
um, I have never changed the coolant on any GM cars. The coolant should last a long time.
Old Jun 7, 2009 | 03:17 PM
StevesBlack06's Avatar
mobil 1 sucks ***** and dexcool is just alright. if i had to switch id run the green stuff or some kinda high end stuff
Old Jun 7, 2009 | 07:47 PM
Maven's Avatar
Awesome insight, LOL.
Evans NPG+ is the best. Any high quality coolant (green, yellow, orange, blue or otherwise) is fine so long as you change it as needed.
Old Jun 7, 2009 | 07:55 PM
Stiner's Avatar
Engine Ice Yo
Old Jun 7, 2009 | 10:08 PM
TRANSAM197781's Avatar
not to thread jack but anybody have any personal experiece with evans npg + ive never heard of it till now would this work well for the supercharger
Old Jun 7, 2009 | 11:02 PM
Do you ever really need to change the stuff? Only time I ever did was when it leaked out due to a hose separating from the radiator.
Old Jun 8, 2009 | 02:10 AM
redlineblueline's Avatar
Its like 5 year 50k miles where as the older green stuff was 3 30 but I flushed my intercooler with prestone universal and its an off green almost yellow color
Old Jun 8, 2009 | 02:12 AM
chris88z24's Avatar
I want to run distilled and water wetter for summer to help with IAT2's but I am worried about rust so I'm just not going to change it at all. haha
Old Jun 10, 2009 | 08:51 PM
ssua's Avatar
Old Jun 11, 2009 | 03:12 AM
PimpLay2's Avatar
dexcool
Old Jun 11, 2009 | 03:41 AM
SprChrg4Life's Avatar
dexcool ;asts 150k miles or 5 years, not 50k miles. so long as your car stays at normal operating temperature, the coolant is working. dexcool will do the job, or yea distilled water and the green stuff. it's all the same, they all do the same thing.
and uh, mobil 1 sucks? our cars require an oil which meets GM4718 requirements... which mobil 1 does. i'd love to hear that you're using castrol syntec, or royal purple or some 'high end' stuff that doesn't, because: "To be able to list the GM 4718M on the container, GM requires that the oil be the latest API service classification, currently the SM. RP has decided not to switch from the SL to SM formulations in the 5W20, 5W30 and 10W30 oil grades as the SM requires a reduced antiwear package and we do not feel it provides as good a wear protection as our current product." ~taken directly from a RP rep from the site. and the castrol, well.. that doesn't meet GM4718 either.
dexcool gets the job done, and for the extra $$ it lasts much longer, so it's worth it. and mobil1 ftw, or these choices http://www.gm.com/corporate/responsi...ngine_oils.pdf
brandon04
Oct 21, 2015 07:04 AM
vjoel2011
Oct 2, 2015 12:11 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
ATOMbomb
Sep 11, 2015 10:48 AM
