wideband install?
Old Oct 28, 2011 | 11:32 PM
rekameohs_nire's Avatar
wideband install?
i recently got a autometer cobalt wideband and just wanted to ask a few questions. i have a stock dp with a gutted cat and wanted to know if the o2 sensor for the wideband will fit on the stock dp. im pretty sure the previous owner had a wideband installed but im not sure. thanks
Old Oct 28, 2011 | 11:38 PM
volsfan92's Avatar
It should.. I have an Autometer and like it..Hope u do too
Old Oct 28, 2011 | 11:49 PM
Chevycobaltss3's Avatar
I want Ure rims.. lol.
Old Oct 28, 2011 | 11:59 PM
keiserX13's Avatar
Just installed my AEM UEGO last week
my A/F is all over the place
not sure if something is wrong with the gauge/o2 sensor or if my A/F is fucked
Old Oct 29, 2011 | 12:03 AM
did you hook up any of the other stuff too or just the wideband function?
mine? ill sell em to you
Old Oct 29, 2011 | 12:05 AM
Lol I need my tranny first lol.. thanks tho. When I had my lsj those rims are the ones I actually weasel buying before it got totalled out.
Old Oct 29, 2011 | 12:06 AM
ill trade ya for your stock tc wheels lol
Old Oct 29, 2011 | 12:11 AM
Lol I dont think Ure rims will fit over my brembos lol
Old Oct 29, 2011 | 12:12 AM
i dont think so either. but thats what spacers are for
Old Oct 29, 2011 | 12:14 AM
Lol.
Old Oct 29, 2011 | 12:23 AM
outtamymind's Avatar
if you have a highflow or a catless downpipe then your AFR will fluctuate quite quickly because of the additional flow. if you have a stock downpipe then it should hold pretty steady around 14.7 idle (assuming its a stock tune)
Old Oct 29, 2011 | 02:31 PM
am i going to be replaceing the current o2 sensor with the new one with the wideband?
Old Oct 29, 2011 | 02:32 PM
which o2 sensor. if its the first o2 sensor you will screw up your fuel trims and cause your car to run like ****. if its the 2nd o2 sensor then your wideband won't be 100% accurate because its behind the cat
Old Oct 29, 2011 | 02:35 PM
i have no idea. ive never installed a wideband or even really looked at the dp. lol what will i be looking at when i lift up the car and where should i put the wideband sensor? sorry for the newb questions
Old Oct 29, 2011 | 02:39 PM
well since its a stock DP your only going to have 1 o2 sensor bung but you do have a gutted cat. so you might be able to get away with putting it in that bung without having any negative effects.
Old Oct 29, 2011 | 02:41 PM
and then i would just take the current sensor out?
Old Oct 29, 2011 | 02:49 PM
yup
Old Oct 30, 2011 | 01:21 PM
seekNdestroy's Avatar
I'm on 60s and it wont stay still to save its life. Itl stay steady wen I do pulls tho. Ima say its normal even if your on a stock or st. 2 tune, since theyr not the greatest out there
Old Oct 30, 2011 | 01:23 PM
I had mine installed om the pass. Side, just put it before the cat where its easily accessible, don't put it straight down tho! Just route your wores so they don't burn on the exhaust
Old Oct 30, 2011 | 01:42 PM
05Slowline's Avatar
lol your wideband will never stay steady the car is always trying to reach stoich at idle google a wideband
to the op yes that will work if u have no cat u will get a p0420 code
wideband readings with a highflow cat will tend to not bounce as much as a catless though
Old Oct 30, 2011 | 07:48 PM
05Slowline's Avatar
lol wut
wideband is placed pre cat in either application
Old Oct 30, 2011 | 08:07 PM
lol what crack was i smoking
what i meant to say is if you have a header or a bigger downpipe then it will tend to bounce more rather then something that is closer to stock.
atleast that is what i have noticed and also have been told from most people that have dealt with widebands and exhausts.
Old Oct 30, 2011 | 10:22 PM
keiserX13's Avatar
yea im running a Catted ZZP 2.5"
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
