will i need a larger fuel pump if...?
guys, im going to be TVS swapping my car, i already have a dual pass, zzp h/e, phenolic spacer and opt. B. this is for my set up now on the m62. heres a list of what all ill be ordering when i order the TVS.
ZZPerformance - Shopping Cart
guessing i shouldnt need anything else, i also will be getting a clutch soon.
Harrop TVS Supercharger HTV1320-LSJ06-02-00734
Option 1: Add LS4 Throttle Body
$2,399.99
$2,399.99
Mototron 80# Injectors (4) SEM-110324-4 EP-ECT-INJ-HRNS
Option 1: EV1
Option 2: Add Injector Harness
Option 3: I am not returning Stock LSJ injectors
$208.99
$208.99
ZZP 3 inch Cobalt CAI ZZ-CB3CAI-RED
Color: Red
$199.99
$199.99
ZZP LSJ 1.0 PCM ZZ-LSJ10PCM
Option 1: I am running 80# injectors
Option 2:
Option 3: TVS Supercharger
Option 4: Tweak tune for meth injection
Option 5: I am running a LS4 throttle body
Option 6: Gasoline tune
Option 7: I am running the ZZP 3" intake
Model: Cobalt SS 2.0L
Core Charge: LSJ PCM Core Charge (200)
Year of Your Car: 2007
Add On:
$349.99
$349.99
LSJ Throttle Body Spacer Plate ZZ-LSJTBSP-LS4-2PP
Option 1: LS4 Adapter Machining
Option 2: 2 Port Plugs
$61.99
$61.99
Aeroforce Intercepter Scan Gauge AF-PT201
Color: White
Option 1: PT
Option 2: Single
$228.99
$228.99
Aeroforce Add on Wideband Kit AF-SENS020
$2,399.99
$2,399.99
Option 1: EV1
$208.99
$208.99
Color: Red
$199.99
$199.99
Option 2:
Add On:
$349.99
$349.99
$61.99
$61.99
Color: White
Option 1: PT
Option 2: Single
$228.99
$228.99
your high too
the stock pump is better then a walbro 255 so a new pump isent needed nor is a boost reference system plenty of people have made way more power then you all have on a m62 and a tvs and on gas long before this **** came along now if you were to be running e and a set of 1000cc inj then yes there is a need for it untill then its money that can be spent better elsewhere
your high
your high also
your high too
your high also
your high too
i know the stock pump is better then a 255 it proven many yrs back and i wasent refering that a 255 would handle the 1000s but that if your going to runn 1000cc inj and e then tyhe rest of the **** is worthwhile
u dont hav to upgrade ur fuel pump even if u are on E..is it safer to yes but u can also jus upgrade the injectors...im still running the stock pump on my set up..i hav an aeromotive stealth i just havent installed it yet
patooyee
Oct 1, 2015 01:07 PM
roth
Sep 26, 2015 12:16 PM
