Will I be OK with stock exhaust and this setup?
Old Aug 22, 2008 | 07:21 PM
boostbalt's Avatar
Hey everyone,
I am installing the zzp front mount heat exchanger (keeping the existing HE on), an injen intake and a RAW Stage I kit tuned for 91 octane in my 2006 SS/SC. Will I have any issues running this setup without any exhaust mods?
Also, what should my first exhaust mod be? I am perfectly happy with the sound of my stock exhaust, I honestly don't want to go too much louder..
Thanks for the advice
Old Aug 22, 2008 | 07:29 PM
ralliartist's Avatar
well, you should be fine. But you are just bottling up the potential on stock exhaust. Get an aftermarket header and dp first, then go with a catback system. That way you get all the performance out of that 2.8 pulley setup.
I commend you on gettin a h/e with the stage kit though. Good job.
Last edited by ralliartist; Aug 22, 2008 at 07:29 PM. Reason: Automerged Doublepost
Old Aug 22, 2008 | 07:34 PM
boostbalt's Avatar
h/e was the first thing that came to mind when I thought 2.8... I know how much heat this engine makes because.......I READ YOUR STUFF! Haha thanks for your info, I will also be adding dual pass in good time... so I will have the stock HE w/ dual pass and a front mount HE, I am stoked, I wonder if it will be cooler then with the stock pulley? Basically at least 3 times more cooling surface/passes then before..
Old Aug 22, 2008 | 07:36 PM
CBodnar's Avatar
^ like he said. you should be fine. also i do not recommend dual pass or option b with cx h/e. not sure about zzp's but if you get it and keep the stock h/e that will be plenty enough my friend.
Old Aug 22, 2008 | 07:39 PM
boostbalt's Avatar
Yea, forget the dual pass?
Old Aug 22, 2008 | 08:02 PM
eh, the dual pass will add more cooling. If you want it, it will help make a tad more top end power by getting rid of some more heat soak. Never hurts.
Old Aug 22, 2008 | 11:38 PM
theneelster's Avatar
Originally Posted by boostbalt
Hey everyone,
First exhaust mod should always be a stainless header/dp combo imo...then catback...for stage 2 or compatible it's a good idea to swap exhaust. Don't need the new h/e before exhaust however. If the raw kit has a 2.8 pulley then you NEED exhaust and the h/e.
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
