will zzp's heat exchanger help me?
cars coolant temp sky rockets when I'm in slow moving traffic or stopping and going for at least 10 minutes. I've seen it hit 236..when I get back to cruising I'm back to 160-175ish. If I get the S3 heat exchanger will it help my coolant temps to wear they don't spike up near that much? I don't want to get something thats irrelevant to my problem.
all you really need to do is make sure your fans are coming on. the engine is designed to run that hot, it isnt really an issue. providing the fans are working, you really dont need to be too concerned. if it bothers you, turn the a/c on and one fan comes on, it will help cool it down. past that you could get somebody with hp tuners adjust the fan tables to get the cooling fans up to 100% speed sooner.
My stock tune had the fans only running at 56% at ECT of 225 degrees. I have my fans set more aggressively since moving to a smaller pulley but it probably isn't necessary.
As others have mentioned the S3 heat exchanger is for your S/C, it does not affect ECT's.
my car in summer sitting it traffic would easily hit 110*c(230*f), however it would generally hit 103*c then slowly creep up, then the fans speed up enough to cool it down. in cooler temps it wouldnt get nearly as hot. its all in the fan programming.
high temps = cookin the oil
my fan kicks on at 220 degrees if im at a stand still. my crusing temps are usually 176-180. but im definetly havign BYT tune it to 200 fan turn on when i get my stage 3 tuned in next spring/summer. i cant wait!
tune!!! my fans kick on at 196*, ive NEVER seen my motor get above 196 since the tune, ever. and ive had some 100+ degree days where i live. i also have a very agressive fan cycle, so my motor cools back down to about 180 in 5-10 seconds haha
, always a good idea to check your intercooler pump because my motor was running about 5 degrees warmer when mine wasent working properly. good luck!
in texas my car with the a/c running sitting still with 113* weather never hit above 200*... driving i seen it hit like 193... but that was me zoomin around on the highway... idk why yours would be hittin that high.. maybe time for a coolant flush???
n20saturn
Sep 30, 2015 12:26 AM
