Wiring Diagram
Old May 14, 2006 | 01:16 AM
SuperCobaltSS's Avatar
Wiring Diagram
Just wondering if anyone knew where to get a wiring diagram for our Cobalts
Thanks
Old May 14, 2006 | 01:19 AM
snobird's Avatar
https://www.cobaltss.net/forums/electronics-audio-video-49/cobalt-audio-pinouts-2823/
thats for the radio i have one here but y scanner is not working i will scan tomorrow and post for you if nobody else has it
Old May 14, 2006 | 11:46 AM
llavalle's Avatar
I just ordered the Service Manual for Cobalt/Pursuit...
When I get it, I can scan pages for you if you want.
Old May 14, 2006 | 01:31 PM
That would be Sweet im looking for the ignition wires so i can hookup my remote start.
Old May 15, 2006 | 03:19 PM
llavalle's Avatar
Alright.. I'll do that..
I just reveived a confirmation from Helm that my manual was shipped.. It should take a week or so to get it (Shipped from USA to Canada)...
I'll keep you informed... if you don't hear from me within 2 weeks, send me a PM.. (I tend to forget things )
Old May 15, 2006 | 03:31 PM
Sweeet Thanks alot man
Old May 15, 2006 | 03:38 PM
fljohnboy's Avatar
You can try this site for wiring diagrams
http://www.bulldogsecurity.com/
Old May 15, 2006 | 08:34 PM
Damn Badass!! worked like a charm. Thanks A Bunch man!!
Old May 16, 2006 | 02:12 AM
TotalEclipseTinting's Avatar
You will still need to bypass the clutch safty switch since the car is a manual. And make sure that it is in neutral before you remote start it into something.
Old May 16, 2006 | 02:15 AM
snobird's Avatar
also you need to bypass the the chip in the key module is like 70 bucks
Old May 16, 2006 | 02:17 AM
Have fun. Every year around Christmas time these new security designs drive me insane
Old May 16, 2006 | 02:22 AM
snobird's Avatar
took me about 2 and half hours to wire mine not too long
Old May 16, 2006 | 02:41 AM
Cobalt_Supercharged's Avatar
I don't think the '05's have the chip, but the '06's do.
Old May 16, 2006 | 03:01 AM
snobird's Avatar
o i will check and post back i know my did and 06 so if not then your good to go damn chips
Old May 16, 2006 | 03:53 AM
Most GMs are mainly "pass key" style.(the key will say PK1, PK2 ect. on the shaft). The ignition will read a certain resitance when the ignition is cylinder is turned. You can test the resistance on the wiring with the key in the ignition(you must bump the starter) and tie in a 5 cent resistor to bypass most gm security systems. I will go to work and see if the cobalt is set up this way and try to get the colors that you need to put the resister between.
Old May 16, 2006 | 04:01 AM
snobird's Avatar
i had to put rsistors in to bypass the factory alarm but for ramote start its different i think
Old May 16, 2006 | 06:24 AM
fljohnboy's Avatar
My 05LS did not have the passkey, I know because I had some keys made at the flea market and they worked just fine. Now my 06SS does have passkey. Kind of strange why some cars do and some don't.
Old May 16, 2006 | 11:09 AM
zinner's Avatar
Moderator Alumni
I also believe the 05 cobalt's don't have it at all. At least my key isn't stamped with anything.
Old May 16, 2006 | 11:52 AM
The 05's dont have it mine dont anyway
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
