Wiring guages
Wiring guages
is there a how to on wiring guages, somehting i can use with some pictures so i can see where the firewall is and hard it is to do. i searched but couldnt find anything so if anyone knows anything about hot to do this please enlighten me!
here is a detailed thread on how to wire a boost guage, and it has a link to another guage install
https://www.cobaltss.net/forums/show...=guage+install
what exactly do you need help with, ive installed two guages (with the help of kaiso^^) so i kinda know what im doing...
why would you want to do the oil pressure? If you have a leak that's oil all over where you don't want it. Why not get the Aeroforce scan gauge and wideband A/F guage. These will be more beneficial.
The hardest part of the install is running the wires. Just take your time and think things through. take a look at how you plan on running the wires before you start and remember to disconnect your neg bat cable before you start.
If you run into any snags just PM me and I will help you out.
cheers
cheers
