Wiring harness difference between 42lbs and 60lbs?
Old Mar 26, 2009 | 09:47 AM
-Jayson-'s Avatar
Is there a difference between the wiring harness from 42lb injectors to 60lb injectors?
Old Mar 26, 2009 | 09:49 AM
ShortStack's Avatar
Yes.
Old Mar 26, 2009 | 10:04 AM
-Jayson-'s Avatar
whats the difference?
Old Mar 26, 2009 | 10:05 AM
Rydis's Avatar
If im not mistaken, the 42's use the stock harness.
Old Mar 26, 2009 | 10:07 AM
ShortStack's Avatar
^^^ Spot on..
Although, if you did buy a new harness with your 42s, im pretty sure they would work.
Old Mar 26, 2009 | 10:22 AM
-Jayson-'s Avatar
I thought the GM kit came with a wiring harness? According to ZZP its because the stock size only uses 18 guage wire.
Old Mar 26, 2009 | 10:24 AM
06black's Avatar
EV1 plug Vs EV6 plug.
foolish human.
Old Mar 26, 2009 | 10:27 AM
-Jayson-'s Avatar
thanks B
Old Mar 26, 2009 | 10:31 AM
ShortStack's Avatar
GM kit does not come with wiring harness.
Old Mar 26, 2009 | 10:41 AM
06black's Avatar
Originally Posted by -Jayson-
thanks B
yea yea.
Old Mar 26, 2009 | 10:54 AM
Zooomer's Avatar
Supporting Vendor
2.0 SS Cobalt uses a Delphi connector on the injector. The GM stage 2 kits include ~40# injectors that use this same plug.
Most aftermarket harnesses convert to EV1 or Bosch connectors. These injectors are available in all sizes.
The 2.4 liter uses an EV6 connector/injector. You can get 60# injectors in this style. ZZP also carries an EV6 harness for the 2.0 but we normally include an EV1 harness.
Easyperformance makes our harness and they claim that larger gauge wire is equal to OEM and better than other aftermarket harnesses. I've never noticed a difference.
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 07:39 AM
Oct 13, 2015 09:32 PM
