it worked... meth on 100oct tune
Old Feb 15, 2008 | 11:15 AM
hungryhip-ccp's Avatar
so for those of you who saw my other posts about the meth on gm stg 3 100oct tune... well it worked the meth completly eliminated the knock and now the 100oct tune stays on even with 91 in the tank... iat2 dropped so fast when activated it was unbelievable... i dont know why i didnt buy this sooner... i mean i know why... its 400$
the best 400$ i ever spent lol so if you dont have it go get it... now order now
Old Feb 15, 2008 | 11:33 AM
rob561's Avatar
thats good to know. congrats. was there a notable increase in performance??
Old Feb 15, 2008 | 11:41 AM
i hate to use this word but it kinda feels like v-tec in a honda... doh there i went and said the h word
Old Feb 15, 2008 | 11:49 AM
QuikSilverSS's Avatar
I re-read the other person on the sites post where he sprayed meth on the gm stage 3, apparently he had the meth being controlled by the stage 3 ecu instead of the NOS so thats why it didnt work well. The guy was RoelSS??
Old Feb 15, 2008 | 11:53 AM
rob561's Avatar
vhmmmmmmmm(hits v-tacccc)vvvvvvvvhhhhhhhhhhhhhhhhmmmmmmmmmmmmmmmmmm
Old Feb 15, 2008 | 12:08 PM
Kibosh3's Avatar
hmmm...another advantage to meth i didnt know about... you can run 91 and a higher octane tune? :O...and its consistant? wow ...i need to scrape some money together...im tired of putting 94 in my tank...expensive and only one gas station franchise i know of offers it
and i've never felt a vtec in a honda...never driven one- does it just kick in after a certain rpm or something?
Old Feb 15, 2008 | 12:25 PM
exactly why i did it! the race gas is outragously priced... and i figured meth is ending up to be 2.50$ a gallon after a 60% water 40% meth and the tank is 1 1/2 so with a 3gph nozzle ide have to hold the throttle to the floor for a half an hour straight to run out so i think it a great alternative... it feels like i gained maybe 10whp....
Old Feb 15, 2008 | 12:39 PM
Kibosh3's Avatar
very nice...and the power just seems to "kick" in?
Old Feb 15, 2008 | 01:09 PM
well yeah the way i have it setup the meth comes on at 10lbs boost seens how thats how much it came with stock so everything should be fine 12.5lbs or less without meth, so its hard to explain how much you feel it but when i roll on to the throttle the boost goes 5 6 7 8 9 10lb and then you see a drop in a/f and a noticable diff is felt... honestly the car runs so much smoother now at wot then before, not that i could notice any ruffness before but it seems like the car just loves the meth/water mixture... it runs so smooth prrrrrrrrrrrrrrrr
Old Feb 15, 2008 | 01:14 PM
invisible's Avatar
Thats good to know...i wonder if it helps mpg also???
Blown 4-banger's Avatar
Meth is bad mmmkay...
Old Feb 15, 2008 | 01:16 PM
shortyhend2004's Avatar
Water/ meth is proven to raise octane and lower temps.....
Old Feb 15, 2008 | 01:19 PM
Werewolf SS's Avatar
What mix of meth/water or you running?
Old Feb 15, 2008 | 01:20 PM
Area47's Avatar
Rent me! per hour
the vtec feeling is from irratic timing.
i have done this just to **** with people.
Old Feb 15, 2008 | 01:21 PM
Until it fails during a race, and pop goes the motor
I've seen it happen before. I used to work at an engine building shop. A motor came in with a couple broken pistons, I asked what happened.... "Meth failed during a run, detonation went off the chart, wreaked havoc on the pistons"
Old Feb 15, 2008 | 01:25 PM
All things have good and bad sides.
For someone untuned and only needs it to lower IAT2 and raise octane it's perfect.
If you run out no diffrence then now.
Old Feb 15, 2008 | 01:29 PM
exactly, im runnin 60 water 40 meth and dont have the money for the cobra heat exchanger
Old Feb 15, 2008 | 01:37 PM
Area47's Avatar
Rent me! per hour
this is why they create gauges.
the afr will go lean. the egt will skyrocket.
Old Feb 15, 2008 | 01:44 PM
Sometimes it happens too quick. At the same shop, we built a B18 for some idiot with a honda running a 100 shot. First time at the track, he installed the fuel jet but, HE FORGOT TO INSTALL A NITROUS JET!!! The instant the nitrous hit, the motor burned up within seconds.
Old Feb 15, 2008 | 01:50 PM
LopsidedJester's Avatar
Its great for the stage 3 though, once the car detects the knock from lack of meth, it will just drop out of 100 octane mode and theres no problem
Old Feb 15, 2008 | 01:51 PM
Kibosh3's Avatar
i hear that with hptuners, you can tune the car to do this as well, correct?
Old Feb 15, 2008 | 01:52 PM
Area47's Avatar
Rent me! per hour
you can run up to 13.4 afr and 23 degree's of timing before you see any severe detonation on a 75/25 mix
Old Feb 15, 2008 | 01:53 PM
OH MY GOD!!!!
Did Area47 just post one of his secrets?!?!?!?
Old Feb 15, 2008 | 01:56 PM
lol^^^ thats amazing^^^lol areA ARE YOU FEELIN OK this morn
Old Feb 15, 2008 | 03:36 PM
No diff. than playing with nitrous.... Usually you dont rely on the water/ meth its a helper not a explosion preventer.
