it worked... meth on 100oct tune
Old Feb 15, 2008 | 07:33 PM
Maxim_X's Avatar
I always thought that would work. Glad to see it did. I was telling a friend with stage 3 that he should do it.
Thanks for the test run!!
Old Feb 15, 2008 | 07:34 PM
hatrickstu's Avatar
what drop did you see in IAT2's?
Old Feb 15, 2008 | 07:54 PM
hungryhip-ccp's Avatar
well i hit a drive through and of course by the time i got and ate my food the temps were about 130 or so and as soon as i took off back down to 80 almost instantly ide say 50 degrees in 5 sec or less
Old Feb 15, 2008 | 10:39 PM
spaz's Avatar
Originally Posted by Blown 4-banger
Until it fails during a race, and pop goes the motor
I've seen it happen before. I used to work at an engine building shop. A motor came in with a couple broken pistons, I asked what happened.... "Meth failed during a run, detonation went off the chart, wreaked havoc on the pistons"
no it won't the pcm will kick it out of high octane mode and you'll be fine
Old Feb 16, 2008 | 11:02 AM
Area47's Avatar
Rent me! per hour
no, it wasn't a secret. it's a limit. nothing more.
Old Feb 16, 2008 | 04:05 PM
thefictionwelive's Avatar
How many gallons of washer fluid are you running per tank?
When do you have it activate?
Old Feb 24, 2008 | 03:26 PM
turboeco's Avatar
What nozzle and what mixture are you running?
You still have it set up to kick in @ 10psi?
Thanks, I'm really liking this setup!
Old Feb 24, 2008 | 04:27 PM
freakta's Avatar
the newer setups have lights that come on when your low so you know youve got to stop running hard before things blow up.
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
