Worked on a Twincharged last night
here is a copmound turbo on a lnf https://www.cobaltss.net/forums/show...ight=lipsticks
the blower stops working after a certain rpm? right?, so the turbo outlet runs through the supercharger? if this is true wouldn't the sc gears limit the potential after a certain rpm?
Totally agree with you man, in fact, I told him when he comes back I will make him a hard pipe inlet and also change the MAF to TB pipe to a 2.75". The kit has 2.5" CP's then it transitions to 3" for the MAF housing then back to 2.5" to the TB. I want to remove that last section of 2.5" and make it 2.75" into the TB. Should also help
That and a 3" exhaust instead of his 2.5"
and im pretty sure my buddies was a full 3" from the turbo back...are you sure his is 2.5"?
that is how the setup was on my buddies so unless they changed it i would imagine its relatively the same
i mean you tell me if 406whp 372wtq is good enough or not...with no lag
so yes, its somewhat restrictive but not to the point where its ridiculous
Um yes...it does lol i drove one, instant power and making all 23 psi by around 3 grand all the way out to 7...pulled like a dream; amazing powerband
No problem, i have a good amount of experience with the twincharge and i saw its ups and downs when it was running great and when it had its problems, and driving it was a shitload of fun too lol
Keep tweeking with the tune and keep us posted because im curious to see how it will drive with your tune vs ZZPs...because, well, theres wasnt the best and thats all i will say lol
I just bought a S/C for my other car (03 Matrix-Turbo) so I can twincharge that car. I have a 60 trim turbo on the thing so the s/c on it will be perfect for my lag situation
Ill post some pics of that thing when it's done too.
Should be a fun project keep us posted
I just use the trim and a/r as a reference to get a general idea of how big the turbo is
How does ZZP control the SC boost in the tune? Do they 0 out the Boost Reduction/Launch control table so the SC bypass valves opens up after 4k?
Exactly! 4k its still holding ok but right after it tapers to 0 by 5k. (tapers quickly)
they stop using the supercharger boost controller becuase people would mess with it and have it bypass to late causing it to compond instead of bypass and cause issues with to much and blow things .
