Worked on a Twincharged last night
Old Aug 26, 2010 | 06:27 PM
  #76
BYT*SS*TURBO's Avatar
No spike at all, I may have a log saved that I can post a screenshot from. If not, Ill be sure to do it when he comes back!
Old Aug 26, 2010 | 11:43 PM
  #77
ebristol's Avatar
Good to know. I'm glad we finally got someone who is jot afraid to share info to spread some light on this subject.
Old Aug 27, 2010 | 12:17 AM
  #78
ralliartist's Avatar
It really is so easy to twincharge I don't understand why more don't do it. You have complete control of the supercharger bypass valve with HPTuners, so there is no need to give yourself a headache with compounding the boost.
Old Aug 27, 2010 | 12:30 AM
  #79
05Slowline's Avatar
lol @ biturbo 4 cylinder.....
looks good in for videos. is this terry?
Old Aug 27, 2010 | 09:52 AM
  #80
His name was Jesse. He's not a member here or any other forum for that matter.
Exactly! For my Matrix project Im going to use the AEM FIC to control the bypass valve, Im hoping that will work well!
Last edited by BYT*SS*TURBO; Aug 27, 2010 at 09:52 AM. Reason: Automerged Doublepost
Old Aug 27, 2010 | 10:01 AM
  #81
fredds-turbaltSS's Avatar
So the SKY is doing a compound set up, theres been multiply twincharged set-ups, why no bi-turbo set-ups?
Old Aug 27, 2010 | 10:53 AM
  #82
ebristol's Avatar
Well not complete control.
The boost reduction table in 1st gear and remaining gears only starts at 4000rpms. So you really can't control the SC before that. At least that I am not aware of.
I think that is the main reason why ZZP recommends running a 256, 256et or 259et on their twincharge setups. Those turbos typically take a while to spool compared to the 252et.
So when selecting a turbo for a twincharge kit you really want to look for something that comes to full spool around 3750 rpms.
Old Aug 27, 2010 | 11:00 AM
  #83
MrSlickSter06SS's Avatar
lets take turns and we all donate to each other and buy this kit just gotta pick straws on who goes first which I hope is me lol
  #84
ebristol's Avatar
The Sky is doing a bi-turbo setup.
https://www.cobaltss.net/forums/advanced-performance-modifications-130/lipsticks-800hp-first-lnf-compound-turbo-engine-build-223923/
Old Aug 27, 2010 | 11:22 AM
  #85
Correct. I had the 4K RPM set to 95 then it tapered down QUICKLY to 0 by 5K RPM.
Old Aug 27, 2010 | 11:28 AM
  #86
ebristol's Avatar
I like you.
Old Aug 27, 2010 | 11:43 AM
  #87
Hes doing a compound build, unless im missunderstanding something and there the same thing. I thought a Bi-Turbo set-up was set up so the small turbo spools the big turbo, and compound basically switches from the small turbo to the big turbo after a certain PSI
Old Aug 28, 2010 | 12:02 PM
  #88
terry11's Avatar
Nope not me... haha Soon tho! Maybe 2 weeks? All depends on who can tune me and when
Old Aug 28, 2010 | 05:16 PM
  #89
I'm going to be using a Holset H1E. Spools in the late 4k on DSMs. 60mm Inducer, 82mm exducer. Makes for a 53.5 trim. Directly comparable to the s362et. Should work perfect on a twincharged car. I got a lot of headwork also, and will be using zzp cams. God I can't wait to get back and put it all together.
Old Aug 29, 2010 | 11:01 PM
  #90
terry11's Avatar
When will you be able to get her all done?
Old Aug 29, 2010 | 11:40 PM
  #91
05Slowline's Avatar
haha ik you were talking about it thought i had 2 and 2 together
Old Aug 30, 2010 | 12:24 AM
  #92
terry11's Avatar
lol that is a weird coincidence. You don't see many twincharged threads around. I just talked to byt and he's gonna tune me as well. I just need to throw the good old blower and manifold back on first
Old Aug 30, 2010 | 05:48 AM
  #93
Next summer, I'm stationed in Germany, and the car is in Nebraska. So it's going to take me a little longer than most cause I have to get leave approved to go home.
Old Aug 30, 2010 | 09:15 AM
  #94
coopercharge's Avatar
This is called a sequential setup like what the 93 rx-7's have for thier TT setup.
Old Aug 30, 2010 | 09:26 AM
  #95
jakeLSJs2's Avatar
I know the guy pretty well. He lives about half hour from me. I saw him friday night at a little meet and when he took off it sounded like a rocket with that dump tube. The car is stupid fast. I plan on doing the kit over the winter. Prolly going to be the only 2 kits in NY!
Old Aug 30, 2010 | 11:56 AM
  #96
terry11's Avatar
Ah i see. What are you boys doing over there?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
jmelton327
Sep 26, 2015 10:04 PM
