WOT Box + Meth
Old Apr 10, 2013 | 06:24 PM
MyOtherSS's Avatar
WOT Box + Meth
Anyone running the N2MB WOT box as well as meth? I've read that it's not good to be spraying while NLS. My meth kicks in at 10 psi by a pressure switch and was wondering if I have the rpm's set to say 4k or so during a NLS will I hold that 10psi+ or will the bypass valve make it drop enough to keep the pump off? I'm just trying to figure how this will work before I install one.
Old Apr 10, 2013 | 06:30 PM
Area47's Avatar
Rent me! per hour
the 2step is what you set rpm wise, not the nls. you set the time on the nls. {leave it in auto}. you can nls with meth. i used to do it all the time.
Old Apr 10, 2013 | 06:42 PM
MyOtherSS's Avatar
ok awesome thanks man
Old Apr 10, 2013 | 07:09 PM
Im gonna be doing this too spraying meth curently and just got my wotbox.
So long as my psi holds ill still be spraying meth while.staging and nlsing
Old Apr 12, 2013 | 06:24 PM
Bump for pointers...
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
