replace injector/possible stage kit questions
hey i have the #4 cylinder injector that went out in my car. I baught the car from a dealer with some mods on it already. They said injector was out and needed to be replaced but they couldnt do it cuz the harness wasnt stock to be able to plug a stock injector into it. they dont know what kind it was eighter. so i was thinking that it might be best to just replace all 4 injectors with a new harness also. This why i know what everything is, and wont have any problems. So basiclly my first question is, is zzp's injectors they sell quality injectors for me to choose to get a harness and injectors from? Also, while im at is, would it be better to just get either a stage 2 or stage 3 kit that way i can add more hp while im at it? And if so, is zzp the best place to choose from? I know if i do this, im gonna have to get it tuned obviously.
any help would be much appreciated.
yea before you start replacing the injectors make sure you figure out what your car is tuned for currently cuz if u have say 60's and throw in 50's it wont be a good idea without a tune.
I would say to have a tuner ready so when ur ready to install u will be able to get tuned and then be all ready to go.
Or if u dont know a local tuner get the can tune from zzp with the stage kit just for now and figure out where to get a better tune after but you will at-least be running on all 4.
I would figure out what injectors and pulley size you have before you go buying anything like mentioned above. I would not go buy a stage kit seeing that your injectors/harness are not oem so you probably have a smaller pulley or stage kit already installed.
Sean Cummings
Mar 9, 2018 12:26 AM
