wot box with nitrous?
Old Feb 14, 2009 | 07:58 AM
stage2cobaltss's Avatar
i know its really bad to be spraying and hit the rev limiter.. well the wot box has the no lift shift.... so what im getting at will i be able to use the wot box while spraying?
Old Feb 14, 2009 | 08:39 AM
redssna's Avatar
I was wondering the same thing. I thought about making a cut out switch or trying to get the programing information from them so I can disable no lift shift when I'm spraying.
Old Feb 14, 2009 | 08:42 AM
slowswap's Avatar
It will work perfectly. All you have to do is wire in a relay from the clutch position switch so when you push the clutch down, it will cut power to the nitrous solenoids.
Old Feb 14, 2009 | 09:46 AM
Maxim_X's Avatar
That may not even be a factor. You may want to check some noncobalt forums to see what others have done. But, I think you could pray and wot shift with no problem. I would expect a nice fireball every shift though.
Old Feb 14, 2009 | 09:53 AM
BLAZIN07SS's Avatar
I'm too JDM for you
no because the no lift shift wot box cuts spark and causes the engine to slightly misfire and you think it will be alright to still throw nitrous in there? hell no, i smacked the limiter on nitrous and the car did not like it at all. shot out a 3 foot flame too
Old Feb 14, 2009 | 11:04 AM
Maxim_X's Avatar
^^ well the limiter is different. That cuts fuel but retains spark, which causes a lean condition when spraying nitrous. That could be very bad. If you wot shift then I figure it will all just get blown out with the extra fuel like normal. I have limited knowledge when it comes to nitrous, but the mixture going through your motor with no spark doesn't seem to be a problem.
Old Feb 14, 2009 | 11:10 AM
slowswap's Avatar
No spraying well not accelerating.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
