wrong vibrations
Old Feb 29, 2008 | 08:51 PM
brownbandit9's Avatar
wrong vibrations
so i thought when everyone was talking about car vibrations from solid motor mount and tranny bushings i thought they ment like you will feel bumps from road and such..NONONO
i get insane vibrations from the motor itself..even when just idling my car is feels like its falling apart...i wish i knew those were the vibrations people ment..i hope this goes away..launches good though
Old Feb 29, 2008 | 08:52 PM
XM15's Avatar
They will diminish somewhat with time.
Old Feb 29, 2008 | 10:24 PM
Nyke's Avatar
I am dealing with the same problem right now. Does yours get tons louder as you accelerate?
Old Feb 29, 2008 | 10:58 PM
LopsidedJester's Avatar
i noticed the vibrations were more at low rpms when i filled my mounts, but my mounts probably still aren't as solid as the aftermarket ones. Definitely helped like brownbandit said launching and shifting are much improved
Old Feb 29, 2008 | 11:19 PM
Nyke's Avatar
Yes my shifting has improved alot, and i have 1st to 2nd traction.
Old Feb 29, 2008 | 11:32 PM
Never Satisfied's Avatar
Sounds like bad motor mounts, or a bent axle..If it is none of those try a engine torque dampner to stabilize the engine
Old Feb 29, 2008 | 11:45 PM
Nyke's Avatar
Tomorrow I will install the stock motor mount to see if the insane vibe goes away, if not then il put back on the stock tranny one, if that doesnt work then i know somethign is very wrong.
Old Mar 1, 2008 | 10:10 AM
MTchevy1's Avatar
It's not bad mounts or axles... it's just the way it is with these mounts. You're feeling the vibration of the motor that the old mounts used to absorb. It'll get a little better, but not a whole lot. It's the price you pay to keep the drivetrain from flopping around like it does with the originals. Annoying as hell, but well worth it in my opinion! If you are still concerned there's a problem, take a ride over here to villa park and take a spin in my car to compare.
Old Mar 1, 2008 | 10:16 AM
06BrandonSS's Avatar
I have about 2000 miles on my trans mounts now and the vibrations are definitely not as bad as when I put them in, but they are still there and I hardly notice them now. Less wheel hop and better launches ftw!
Old Mar 1, 2008 | 10:22 AM
D4u2s0t's Avatar
he has a solid motor mount. it's just going to vibrate more.
you get used to it after a while. after a while you won't even notice it anymore. and if you're getting better traction, that's the trade off, vibrations. i only get them noticeably now when going very slow in gear.
Stouffer's Avatar
It's normal and they will diminish slightly and you will get used to it.
Old Mar 1, 2008 | 04:04 PM
yah i just noticed when im taking off like normal at a light the car is really boggy around and under 2k rpm..
Old Mar 1, 2008 | 06:15 PM
Nyke's Avatar
Just enguage sooner on the clutch and it wont be as boggy, your probably not enguaging fast enough.
Anyways I removed my ZZP Motor mount and put in the stock one, so now i have the Stock motor mount and 2 ZZP Tranny mounts, and holy **** did the vibrations calm down.
ZZP Motor mount is just to damn stiff for me. I will try it again when the 2 tranny mounts break in fully, until then it is staying off!
hacadacalopolis
Oct 28, 2015 06:09 PM
chefhhr
Oct 26, 2015 10:36 PM
no_ss
Oct 18, 2015 11:58 PM
Tupp
Sep 30, 2015 08:18 PM
