WTF? attempted boost bypass and lost boost?
i have a 07' ss/sc with the g85 package. i was screwing around and figured id just try the "boost bypass" mod. well i made sure the top vaccum hose was not leaking and i lost 1.5lbs (roughly) of boost, the car car was much slower? infact after i plugged it back in the car was fine again? knowing my ******* self i prob. screwed somethig up in the process, but has anyone seen this?
Boost Bypass Mod Doesn't Work!
Guys this "Boost Bypass Mod" does absolutely nothing for performance.
We have had guys dyno before and after with 0 results.
So in other words, don't waste your time.
This whole myth started back when there were very few aftermarket parts for the Cobalt and people needed a fix.
Thats exactly what i thought when i tried it when someone first said to try it, then i noticed my boosy dropped from 18 to 15 and then i just said screw it, it doesnt work.
isnt this to when u boosted the car with a smaller pully it was to prevent the car to bleed the boost back to the factory 12.5lbs of boost when running a smaller pully and hptuners diddnt have the ability at the time to bleed the boost or turn off the boost when its above the lbs of boost the new pully gives .
if i am wrong please correct me for this is all i remember
Originally Posted by memphisr24
It just messes with the a/f ratios BADLY. I was only seeing like 16 psi with my 2.5 pulley, plugged the line, saw about 17-18, but then I started to get like a couple degrees of knock.
When you add more air you create more heat inside the combustion champer promoting pre-ingition which can cause knock. Also when you increase the boost, you increase your VE (volumetric efficiency) which then causes the ECM to follow a different path on the spark table, which can cause higher timing = knock
Sl0wbaltSS
Nov 21, 2018 11:11 PM
