wtf is wrong. turbo guys help.
Old 12-24-2008, 06:49 PM
slowswap's Avatar
Originally Posted by 06blackg85ss
garrett does make non gt series turbo's you know.
Well no **** but you said look it up on Garrett's site. I went on there to try and find some compressor maps. Surprise, it's not listed there.
Old 12-24-2008, 07:03 PM
Jn2
Jn2's Avatar
http://www.turbofast.com.au/FlowTO4E.html
a lilttle research goes a long way, t3/to4e 57 trim compressor map is in there
Old 12-24-2008, 07:13 PM
bwalker0510's Avatar
ok guys no offense but can we please stay on the original threads intentions please. lets not argue it up. thanks guys. i luv all of you still.
Old 12-24-2008, 07:29 PM
Jn2
Jn2's Avatar
wellu said it runs out of breath what do you mean? the powr die off? i know that happends on the ms3, my bud has one and on the dyno there is no high end at all, is that what is going on? im sure the turbo is good for more psi if you want more power
Old 12-24-2008, 07:51 PM
Maxim_X's Avatar
Is the dyno reading jagged at the end of it? I am still unable to get full power out of mine. The car ***** out at about 5k whenever I am at high boost. the only thing in the log that i see is that the maf readiung stps changing at all when that happens. it pulls all timing my car basically *****, almost like a rev limter.
I have to stop trying to tune and looking trough everything because I need to pass inspectiona and the car hates to ready for evap. Maybe we have a simmilar problem.
Blow through or draw through?
Old 12-24-2008, 08:16 PM
HunterKiller89's Avatar
sounds like your doing something like maxxing out the MAF, so it runs in the safest possible settings (IE pulling all possible timing). I know if you unplug the knock sensor, itll drive fine until you get into PE, where it then pulls just about all your timing.
neither of these sound like the issue the OP is having though, but the MAF one might be on you want to check out for yourself
Old 12-24-2008, 08:21 PM
Maxim_X's Avatar
I thoiught that too. But, on different pulls the maf levels out at different numbers. I would figure if i maxed it out it would be at the same reading everytime.
Old 12-24-2008, 09:51 PM
Rent me! per hour
Area47's Avatar
boost leak.
3 inch maf pipe is needed.
timing?
afr?
Old 12-25-2008, 12:03 AM
spike's Avatar
Originally Posted by Area47
boost leak.
timing?
afr?
+1...........
vjoel2011
10-02-2015 12:11 PM
Shane H
09-24-2015 11:07 AM
TylerJHowell
09-21-2015 06:47 PM
twilson380
09-14-2015 10:52 AM
CobaltSS 16
09-12-2015 02:43 PM
Quick Reply: wtf is wrong. turbo guys help.
