zzp brfps boost reference fuel installed - Fuel Lab - w/o evap add on
Old 06-02-2013, 04:17 PM
YelCal7's Avatar
You may want to get this that way you can see your fuel base setting. Cause this is what I would want to do. Link->Fuelab 71511 Fuelab Fuel Pressure Gauges
Old 06-02-2013, 04:26 PM
c130aviator's Avatar
I want to put it on the rail, where do I find those end caps that bolt onto the LSJ and allow a gauge to be added to the end of the rail.
Old 06-02-2013, 04:29 PM
YelCal7's Avatar
As far I know that OTTP has 1 but I don't know if you wanna take it up with them.
Old 06-02-2013, 04:40 PM
honestly when I get on the dyno if there isnt more fuel it will show up in the AFR. I was pushing 23 psi before I started running slightly lean. If its set up right I should run it out to 25-30 psi without AFR issues. So we shall see. Still going to look into a gauge just for the peace-of-mind.
Old 06-02-2013, 11:05 PM
mrbelvedere's Avatar
Originally Posted by derboy8
this is true but im glad he didn't know bout the car he had and I got to buy it...well rip him off...Ill put it nicely take it off his hands hahaha
your a bad ass said no one ever
It has lots of good parts on it but we got to get you running E85 and way more cooling mods. Thanks again for the help today.
cooling mods lol
you need the gauge to be able to adjust the base pressure without it your pissing in the wind
Old 06-02-2013, 11:47 PM
Tjolley's Avatar
They like pissing in the wind. Lol
Old 06-03-2013, 12:55 AM
lol, not sure what belvie said he is on my ignore list but I am sure it was smart in reply. Its not pissing in the wind on a dyno Tjolley. What better tool than to watch what AFR's as you adjust fuel pressure at WOT. There are a bazillion threads with replies in it from Matt (zzp) regarding the lack of necessity concerning a gauge.
Old 06-03-2013, 07:00 AM
Tjolley's Avatar
Oh and u might be out of fuel pump. And crankin up the fuel pressure will lower the pumps volume. So do me suprised if u r srill running out of fuel cuz the pump cant keep up.
Old 06-03-2013, 05:42 PM
The pump does probably need some work, gonna use the one you suggested in your build thread. I am doing my own pump rewire since zzp is out of stock. picked up a relay and a wiring kit and should be a quick easy install.
Old 06-03-2013, 07:23 PM
Tjolley's Avatar
The stock works fine..no need for that ****. My zzp rewire kit burnt uo after a year of use left me stranded 100 miles from my house at 2am
Old 06-03-2013, 07:25 PM
  #36
Tjolley's Avatar
A few others on here have had it heppen to them also
Old 06-03-2013, 07:38 PM
  #37
hey jolley when your dumb you suffer
Old 06-03-2013, 08:23 PM
  #38
Tjolley's Avatar
Ya i learned my lesson on that one.
I wouldn't give it away after all the problems its caused me. Ill do my own set up if i end up needing the second fuel pump for beast mode.
While all ur snails are spooling ill be winning
Old 06-03-2013, 09:46 PM
  #39
I'm too JDM for you
BLAZIN07SS's Avatar
because all of us lag so bad? 26psi at 3700rpm on a 56mm turbo on a complete stock motor btw
Old 06-03-2013, 10:11 PM
  #40
ebristol's Avatar
Originally Posted by Tjolley
Ive had my setup for over a year, works fine.
The full return style is a wast of time in my opinion. I actually think it can affect performance on a supercharged car.
dumbest **** i have heard on this forum in awhile
It is up there!
Either way this is the best write up for a ZZP product that ZZP said was completely useless just a couple of years ago and jokingly charged $99,999! lol
Of course most of you kids don't remember that...
Old 06-03-2013, 10:24 PM
  #41
Tjolley's Avatar
I remember that
Old 06-03-2013, 10:50 PM
  #42
thanks ebristol
blazin what are you running for fuel system? pump? etc.
Old 06-03-2013, 11:05 PM
  #43
I'm too JDM for you
BLAZIN07SS's Avatar
ott return style fuel system
walbro 255lph pump
injector dynamics id1000's
and of course e85
Old 06-03-2013, 11:29 PM
  #44
armcclure's Avatar
saying you don't need to know base pressure is saying you don't understand injector settings and scaling...
also, if you installed it option1 (stock reg in place) you CAN'T acurately adjust the base pressure and therefore the injector settings.
will it work? yes. will it be right? no.
Old 06-04-2013, 12:03 AM
  #45
I am ordering a gauge, I understand base pressure, just dont need to mess with idle on E since you need 27 percent more fuel to create the right stoich for an engine. So if base is 58-60 psi and I throw 17 lbs of air down the regulator and I increase a psi of fuel per PSI while setting up the car. The power enrich will take care of the rest as I adjust the table on the dyno. That may matter more on a PCM that is better than our crap P12 ECM but its still done right. Just not the way you think it should be done. There are many reading these threads and generalizations are not going to fit everyone.
Old 06-04-2013, 09:29 AM
  #46
p.e. will not take care of the rest its not self adjusting
Old 06-04-2013, 09:45 AM
  #47
user 72239's Avatar
I had him on ignore for awhile too but the stupid **** he says just makes me laugh so i had to take him off.
Old 06-04-2013, 11:39 AM
  #48
good put me back on ignore *****
Old 06-04-2013, 11:41 AM
  #49
user 72239's Avatar
here is one of those times haha. you are the biggest moron on here. I think even Cobe is better than the **** you say.
Old 06-04-2013, 11:45 AM
  #50
oh look your butt is aching
Quick Reply: zzp brfps boost reference fuel installed - Fuel Lab - w/o evap add on
