ZZP CAI Fitment Question
I bought a used ZZP CAI from ULWiz on here. Installed it yesterday and when I put the plastic fenderwell piece back in, it doesn't seem to sit flush like it's supposed to now because it hits the intake. Is this normal? I tried to adjust it so that it wouldn't but there is not a lot of room at all for that thing to move. Also the bracket by the maf sensor, where does that bolt to? Any help or suggestions would be great.
Do you have the new revised one or the older one with 2 pieces and 2 couplers?
I know when I had there older intake (2pieces) I had to mess with it a lot to get it to fit perfectly....but did after that
It's the revised one piece. The 2 piece would have probably been eaiser to install lol. Man was that a tight fit to get in! And theres hardly any room to move it for adjustment. I don't have that bracket bolted up which is probably part of my problem but I can't see where it bolts to unless you have to drill your own hole?
