zzp cams
Old Feb 16, 2010 | 10:09 AM
mrbelvedere's Avatar
zzp cams
anyone running them if so what about the lash adjusters and the camposition sensor and what kind of power do they make
Old Feb 16, 2010 | 12:32 PM
Supercharged Guy's Avatar
I didnt know that ZZP made cams. I thought they only had comp and the GM ones.
Old Feb 16, 2010 | 01:55 PM
ebristol's Avatar
So is anyone running the COMP cams sold through ZZP?
Old Feb 16, 2010 | 01:57 PM
hungryhip-ccp's Avatar
http://www.compcamshafts.net/informa...ECOTECCams.pdf
Old Feb 16, 2010 | 02:07 PM
bolus's Avatar
Do those actually work in the 2.0L LSJ or does compcams expect people to weld on the hex on the exhaust cam?
Old Feb 16, 2010 | 02:09 PM
I was thinking about purchasing the cams (the comps) but didnt really see a point if I wasnt doing a full build, maybe in the future yes.
Old Feb 16, 2010 | 02:14 PM
ebristol's Avatar
Turbo Tim from ZZP is running the Stage 3 cams.
Those are the same cams they ran in the 1900 article in the Hot Rod mag. (I am not sure which stage)
Originally Posted by Turbo Tim
We just did a twincharged '06 Cobalt with our ported head and a pair of cams that are a little smaller than the Stage 1 cams. The factory cams are pretty good stock, but keep in mind, as soon as you change the cams you will be shifting at 8k+ rpm. I will have to see what I can do about some A -B dyno graphs.
Old Feb 16, 2010 | 02:35 PM
How much are the stage 3 cams?
Old Feb 16, 2010 | 06:01 PM
im wondering about the if the base circle is big enough and if you still run the cazm sensor
Old Feb 16, 2010 | 11:44 PM
bolus's Avatar
I called compcams today. They didn't seem to know that the 2.2 and the 2.0 had different sized cams and they only had one part number for the ecotec. It's like they just wrote on the website that the cams would work in both but really didn't actually try to fit them in the LSJ.
Even GM says the comp cam exhaust cam wont fit in the LSJ (at the bottom)
http://gmtunersource.com/media/racer...FO-SHEET-2.pdf
May be someone from zzp can clarify here? Is there a specific comp cam kit for the LSJ? Or are they taking the intake came and modifying it to work as an exhaust cam? or taking the exhaust cam and welding on the fitting for the sensor?
Old Feb 17, 2010 | 02:45 AM
Omnigear's Avatar
so how much more overlap and vacuum loss do you get with this cams?
Old Feb 17, 2010 | 06:24 AM
victory_red_SS's Avatar
LSX RWD S/C conversion
If you guys are after cams, get a hold of Bates Engineering. He has billet cam blanks for the 2.0 and then Comp grinds them for him. You will need to buy the solid lifters but Bates has them for about $7. each.
Old Feb 17, 2010 | 09:36 AM
ebristol's Avatar
Are their any cam options for people who don't want to deal with solid lifters?
Old Feb 17, 2010 | 11:30 AM
euthanasia's Avatar
We saw about 11-12 inch of vac.
Old Feb 17, 2010 | 11:32 AM
bolus's Avatar
OK I got some more information. COMPcams uses a blank intake cam from the 2.2 and puts the exhaust pattern on it. So it is a custom part.
Old Feb 17, 2010 | 02:44 PM
Zooomer's Avatar
Supporting Vendor
We order our cams from Comp but they don't support this market heavily so they rely on us for a lot. We have specific ways to order what we need and sell. We clock and lock the hex here before shipping because Comp can't seem to do this.
Old Feb 17, 2010 | 02:53 PM
^ Are you guys coming out with cams anytime soon?? ^
Old Feb 17, 2010 | 02:55 PM
it says you just specify 2.0
Old Feb 17, 2010 | 03:22 PM
bolus's Avatar
Thanks, so you finish them off. How would one specify that they are ordering for an LSJ on your site? I does not seem to give a place to choose for 2.0 or 2.2
http://www.zzperformance.com/cobalt_...1124&catid=143
Old Feb 18, 2010 | 12:20 AM
Dennisscars's Avatar
If it comes clocked as intake, other than throwing a P0017 code, and if you ignore will it still run right? Seem like that throws it off about half a hex.
Worried about going into some weird limp mode at a most inopportune time.
no_ss
Oct 18, 2015 11:58 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
