zzp dp
thats normal with zzp they will only put one for catless only if you order an extra bung, with a catless downpipe, you wont need the rear o2 sensor as most people will disable that in their tune....
If you ordered a dp without the wideband o2 bung you wont have any bungs on ur dp...
where is this bung?I have this down pipe too, and that bung placement is wrong for the wideband on mine its only the downstream one, The wideband needs to be the closest to the exhuast manifold for the best and most accurate reading.
where it should be
where it should be
