ZZP or GM
Old Jun 26, 2008 | 02:00 AM
ZOLOMAN3000's Avatar
ZZP or GM
should i go with the gm stage 2 kit with custom tune or the zzp stage 3 with there tune? i think they would about be the same because its the same pulley size and same injectors
Old Jun 26, 2008 | 02:01 AM
JRelly's Avatar
Just build your own kit and get a custom tune
Old Jun 26, 2008 | 02:06 AM
EXsoccer1921's Avatar
i'ld have to agree.
just get what ever pulley size your mods will allow, i'ld go ahead and get some 42's, and then a custom tune for the type of driving you'll be doing. ie WOT, or just efficient power for DD
Old Jun 26, 2008 | 02:08 AM
JohnsRallyYellowSS's Avatar
^^^^^x2 build your on kit, 60# injectors, 2.9 pulley, custom tune FTW!
Old Jun 26, 2008 | 02:14 AM
I'm savin up my money for 12k miles till my warranty is up. then i'm buyin (this is the current list hahaha)
cobra or cx h/e, dual pass, option b for dual pass, meth injection, injen cai, 2.7, 60"s, 3" custom header back exhaust(w/ header of course), stage2 axels, 50 wet shot, valves, valve springs and retainers, comp cams intake and exhaust, and more than likely a cnc ported head. with a dyno tune
Till then it's still just a daily driver
Old Jun 26, 2008 | 02:31 AM
how are the intake temps on a 2.9? i just checked on zzp to make my own kit and with 60# injectors wiring harness shortened belt and pulley with hub would cost like 400
Old Jun 26, 2008 | 02:36 AM
JRelly's Avatar
You can get injectors with a harness on here from someone for around 200 or less, you can get the belt from CED for 45, and you can get a pulley and hub from Smoothflow for 90
Old Jun 26, 2008 | 02:42 AM
thats helpful but still how are the intake temps on the 2.9 can it be much higher then the 3
Old Jun 26, 2008 | 02:46 AM
It has been about 95* around here the past few days and the hottest post blower temp I have seen is about 145*
JRelly's Avatar
No they arent much higher then the 3, many people run 2.9s without any problems. Im personally gonna be running a 2.85 and 60lbers with a custom tune.
Old Jun 26, 2008 | 02:54 AM
so with the 2.9 i should go with the 60# right because i heard that the 3 almost maxes out the 42# the price difference is only like 20 dollars so i would rather be safe then sorry
Old Jun 26, 2008 | 03:04 AM
JRelly's Avatar
Thats a highly debated question on these forums, but yes most charts show that the 42lbers are or are almost most maxed on the 3, but many run a 2.9 and 42lbers with no problems. But either way getting the 60lbers is a better idea just to play it safe and if you want to go down in pulley size later on you will not need to buy injectors again.
Old Jun 26, 2008 | 03:08 AM
thats true because i was thinking for in the future getting a menthol kit and going with a 2.8 or smaller
thanks for the help guys
Old Jun 26, 2008 | 03:11 AM
what about using a return style fuel system on a 2.9 and 40's??
Old Jun 26, 2008 | 03:12 AM
JRelly's Avatar
No problem, meth is a great mod for these cars no matter what pulley you are running
Old Jun 26, 2008 | 03:19 AM
eurochevy's Avatar
custom tune is the way to go unless you worried about warranty and stuff
Old Jun 26, 2008 | 05:34 AM
Zach06CobaltSC's Avatar
custom tune x a million. Get all the cooling mods, heat exchanger, dual pass, meth, and then 60lbers and a 2.7inch pulley and a tune from a shop you trust.
I also recommend buying some gauges, like an interceptor and a wideband.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
