ZZP Headers + Downpipe
Old Mar 26, 2009 | 05:20 PM
galeblanc's Avatar
Hi,
So I've decided that I may only get some headers + downpipe from ZZP probably. I have an SS/SC 06 with Stage 2 and I'm stock other than that. I've decided not to get the cat-back because of the law enforcement over here.
So is this a good idea to keep the stock cat-back and install the headers + downpipe? Will it improve performance + sound? Are there other manufacturers better than ZZP?
Finally, what is the best setup with the mid-length ZZP combo?
Thanks
Gabriel
Old Mar 26, 2009 | 05:34 PM
2MCHBoost's Avatar
Originally Posted by galeblanc
Hi,
Thanks
Gabriel
The exhaust will be louder and you will get nice gains with the smaller pulley. Best combo to go with is a 1 3/4th painted mid length with a 3" downpipe and a 2.5" exit.
Old Mar 26, 2009 | 05:38 PM
galeblanc's Avatar
Thanks for your quick response ... So just to confirm my ideal option if I keep my stock cat-back is :
1-3/4 HIGH TEMP PAINT
Mild Steel
3" DP w/ 2.5 Bolt In
What is the magnaflow cat? Not good? I guess straight is better?
Thanks again!
Old Mar 26, 2009 | 05:40 PM
2MCHBoost's Avatar
Mild Steel
Thanks again!
Magnaflow cat is good if you have to pass a visual inspection. No cat will yield more gains but it all depends on what you have to pass when it comes to emissions
Old Mar 26, 2009 | 05:46 PM
ebristol's Avatar
A bunch of people have had problems with the ZZP midlengh header/dp combo leaking.
The reason being is that ZZP uses a two bolt flange to connect the header to the dp. Almost every other company uses a 3 bolt flange.
For a nice inexpensive solution I have been recommend the CA V2 header with a ZZP dp.
You can get a CA V2 header on ebay for $215 shipped. A brand new ZZP cat'd dp is around $200.
I bought that setup for my TVS and then changed my mind and got a CTI midlenght header and dp.
But I think the CA V2 shorty header would be perfect for a stage 2 car.
Old Mar 26, 2009 | 06:08 PM
chris88z24's Avatar
**** yeah dude. I have the ZZP midlength, 3" catted DP, and STOCK catback. Really woke the car up and doesn't sound like a riced out piece of **** going down the road.
I've said it time and time again, you do NOT need to change the catback on these cars for power. Header and DP, leave the rest alone.
Old Mar 26, 2009 | 09:19 PM
galeblanc's Avatar
Is this what you have ?
Car:Manual
Model:1 3/4 inch high temp paint
Option 1:Magnaflow cat
Option 2:Mild steel downpipe
Option 3:3" downpipe, 2.5" exit, bolt in
I'll probably take the same thing but without the Magnaflow Cat cause I doubt I'll have to go for an inspection. I'm really happy that I found a solution without the risk of being harrassed by the police.
The sound has really improved from stock ?
Old Sep 8, 2010 | 10:47 PM
babyCobaltss's Avatar
Smile
So are you saying it would be wise to just get a header and Dp and leave the stock exhaust system on my Cobalt SS 06? or should i buy an exhaust and the header/dp from zzp? any help?
Old Sep 9, 2010 | 12:45 AM
b00sted06ss's Avatar
a catback isnt a necessity but it doesnt hurt to have one
Old Sep 9, 2010 | 12:50 AM
Perfect.disguise's Avatar
You can put in a better header/downpipe but the OEM catback is still a bottleneck.
Old Sep 9, 2010 | 01:25 AM
so i will be ok running the OTTP stage 2 kit for a month or so with only the Vibrant header/dp and DC Sports CIA? This is until i can buy a heat exchanger and the catback.
Old Sep 9, 2010 | 02:10 AM
Could i run a ZZP downpipe with a Pace setter header? Pace setter seems to be cheaper..are they decent?
Old Sep 9, 2010 | 07:23 PM
skatin_boarding's Avatar
a custom down pipe will need to be made for the pace setter.
Old Dec 26, 2010 | 05:06 PM
sjc0013's Avatar
Window Licker
Ebristol did you ever bolt on this setup? I'm thinking about going this route. I know a shorty header is not the best setup for big gains but its gotta be a lot better over stock right? Also, is the badmab header the same as the ca v2?
Old Dec 26, 2010 | 05:31 PM
olivecj's Avatar
Hi,
Thanks
Gabriel
You could just chop your stock muffler off and get a dynomax turbo muffler thats what I did and it sounds really good and barely louder than stock.
Old Dec 26, 2010 | 05:39 PM
blk06cbltss's Avatar
my setup =D sold the xtc catless and now about to order the zzp 3" to 2.5" exit
Old Dec 26, 2010 | 05:42 PM
sjc0013's Avatar
Window Licker
You pleased with that header? Im thinking on going with that and full 3" zzp dp.
Old Dec 26, 2010 | 05:43 PM
um i gotta reweld it. got a hairline crack in it(where all the pipes come together) =( other then that it does what a header does
Old Dec 27, 2010 | 05:23 PM
ebristol's Avatar
I actually never did. I sold it before I installed it and got a CTI header/dp combo.
Old Dec 27, 2010 | 06:09 PM
Render2009's Avatar
im currently running badmab header and zzp 3inch catless dp with a vibrant resonator, then stock catback with magnaflow muffler swap. i wanna get a catback but idk if the gains will be worth it. and im trifecta gms3.
Old Dec 27, 2010 | 06:18 PM
Blown07SS's Avatar
I have had 3 headers and a aftermarket exhaust. I'm now on vibrant midlength with downpipe setup and stock exhaust and feel it's better then the stock header with aftermarket cat back. Trust me get a header and downpipe first then get a exhaust last
Old Dec 28, 2010 | 07:53 PM
BADMAB's Avatar
Supporting Vendor
Yes, the CA V2 and BADMAB header are the same:
BAD-MAB.com
Old Jan 1, 2011 | 04:35 PM
sjc0013's Avatar
Window Licker
awesome! will be ordering from you guys in a few weeks
Old Jan 1, 2011 | 05:28 PM
BADMAB's Avatar
Supporting Vendor
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
