zzp intake spacer
Old Jun 13, 2012 | 09:02 AM
motosledneck12's Avatar
zzp intake spacer
does anyone know if zzp's intake spacer comes with the new updated gaskets per the G.M. bulletin about the dipstick blowing out.
Old Jun 13, 2012 | 09:14 AM
Bluelightning's Avatar
Got Bewst?
I'm going to say no. The gaskets they give are aftermarket and much cheaper looking than GMs. But what do you want the whole spacer kit is $100. I thought it was just a valve cover venting problem that causes the dipstick to push out?
Old Jun 13, 2012 | 11:08 AM
Well G.M. now has a bulletin out about the gasket being updated because the pcv is ran through the second runner on the intake manifold and they are having problems with boost pressure being pushed into the pcv system and hence blowing out the dip stick. so i think i will just order 2 of these gaskets from G.M. sence i am have my dip stick shoot out at 22 psi and im putting in the spacer, why not right?
Old Jun 13, 2012 | 11:15 AM
YelCal7's Avatar
No, You can't cause Phenolic Spacers are like resins. If you get 2 metel gasket and put Phenolic Spacers, you will end up melt your Phenolic Spacers. Use ZZP's gaskets what they provide for, that way your Phenolic Spacers won't melt. I am using ZZP's Phenolic Spacer and I use ZZP's what they provides for. Everything is fine so far. You will be fine, use what ZZP's provides for this kits. You won't be disappointed at all, it's worth it.
Old Jun 13, 2012 | 11:23 AM
Got Bewst?
I run 24psi and don't have any issues. But instead of changing the gaskets I would go with this
https://www.cobaltss.net/forums/2-0l...lution-238736/
Old Jun 13, 2012 | 01:58 PM
thanks for the link i just order the ls series vented oil cap hopefuly that will help
and i will just use the gasket the spacer comes with and try it out
Old Jun 13, 2012 | 03:37 PM
mrbelvedere's Avatar
thats old news
the vented oil cap can cause the engine to go lean the problem is the vent on the back of the valve cover isent big enough
Old Jun 13, 2012 | 03:53 PM
Originally Posted by mrbelvedere
thats old news
the cap has a check valve in it so air can only go out and not in
Old Jun 13, 2012 | 10:51 PM
nhanson's Avatar
I was going to use the phenolic but didnt and still used one of the gaskets that was in the kit. Seems fine to me.
Old Jun 14, 2012 | 08:57 AM
why did you not use the spacer if you dont mind me asking?
Old Jun 14, 2012 | 11:36 AM
nhanson's Avatar
Im a 2.2 thats auto so the engine sits forward more than a manual. Plus my belt was a super bitch to get on as is.
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
