Zzp PCM and 60lbs??
Zzp PCM and 60lbs??
Going from my current set up to a zzp PCM, 60s, and a 2.8 pulley i should notice quite a difference I would think? Also wut kind of numbers should I putting on the the dyno with that setup and the rest of my mods? Everything is In my sig.
Thanks
Thanks
Would the money be worth the gains? My other problem is there is no one in my aera that could tune the car.
After lunch bump
After lunch bump
Yes the ZZP computer will come with a tune but its going to be a canned tune, which is not going to be the most power you can get out of the mods you have.
Nobody in your area has HPT or any performance/dyno shop that can do it?
Nothing close by. The closest shop I would trust is a four hour drive .
