ZZP Stage 3
Old Jun 17, 2013 | 03:22 PM
Jeff876's Avatar
ZZP Stage 3
2004 redline, 91 octane, probably a devils own meth kit
1. 2.5 or 3 inch exhaust? (full, header and dp as well)
2. 60# or 80# injectors?
3. Is 2.8" Pulley safe for a DD that only has access to 91 octane?
4. Should I Invest in HPTuners ? Or should i just get the "pcm core charge" one which I assume gives me a PCM with a tune on it?
5. Shorter belt or adjustable tensioner/oversized tensioner pulley?
Assuming 91 octane, meth kit, 2.5 or 3" exhaust (assuming 3" is better) , good tune and 2.8" pulley (feel this is the safest option for me) will i be anywheres near 275-280 hp? or less,more?
Just checking out my options
Old Jun 17, 2013 | 03:25 PM
Hockeyman's Avatar
2.5" exhaust
60# injectors
2.8" pulley is safe, especially if running meth
Tune - Best to find a reputable local tuner
Shorter belt is fine
270-280 CRANK hp is possible. To the wheels you will likely be 250ish.
Old Jun 17, 2013 | 05:42 PM
mrbelvedere's Avatar
ok first off there is plenty of info on here about what you are doing so search and secondly we have a dyno section that can give you an idea
Dyno Results - Cobalt SS Network
no_ss
Oct 18, 2015 11:58 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
