zzp stage 3 sc kit
Old Jan 10, 2011 | 10:23 AM
T CUPP's Avatar
zzp stage 3 sc kit
i am planning on getting this kit with the 2.7 along with stage 3 heat exchanger dual pass and option b. but the question is what is better the oversized pulley shorter belt or what?
Cobalt & Ion ---> ZZ Performance
Old Jan 10, 2011 | 10:24 AM
coopercharge's Avatar
I went with the oversized pulley and just notched out the stock tensioner. The stage 2 belts are prone to failure from what I understand.
Old Jan 10, 2011 | 10:26 AM
Staged07SS's Avatar
Administrator
Administrator
I have never heard of such a thing.
Old Jan 10, 2011 | 10:50 AM
T CUPP's Avatar
which one would be better performance wise?
Old Jan 10, 2011 | 10:58 AM
stonny9's Avatar
I have never heard of that. My GM stg 2 belt has over 50,000 miles of running a 2.8. Belt shows zero signs of failure. Boosting 15 lbs over a dozen times a day. Belt was made in 2007 at the latest.
I dont think it really matters what you get. There is no performance difference and they both wear out over years of use. If your blet has cracks then definately go with a new belt otherwise it is up to you.
Staged07SS's Avatar
Administrator
Administrator
You will not notice a difference in performance from a belt or a tensioner.
The GMS2 belt will work perfectly fine down to a 2.7" pulley w/o any slipping issues.
If you plan on going below a 2.7" pulley get the adjustable tensioner.
Old Jan 10, 2011 | 10:59 AM
I just remember reading something about sounds like im wrong.
Old Jan 10, 2011 | 11:01 AM
T CUPP's Avatar
i am just going to a 2.7 but the zzp shorter belt should work?
Old Jan 10, 2011 | 11:02 AM
Staged07SS's Avatar
Administrator
Administrator
Yes.
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
