ZZPerformance Pulley
Old Dec 13, 2005 | 10:17 PM
silverSS's Avatar
http://zzperformance.com/cobalt_ion/...ts1.php?id=451
looks like they have 3.2, 3.0, 2.8...i know a couple people are running these on the redline and cobalt SS's...ive seen them in action too. These are often referred to as the "ebay pulley"
share your experiences with the company, and the product..only $60 for a pulley!
This is making me lean towards them over SFPH and bilelltflow hasnt realeased theirs yet.
One question i need answered: can you run the stock size pulley with the SFPH kit?
and i think SFPH sizes are off...for one, the stock size is not 3.5, i thought it was 3.35? Also, SFPH claims you make 14-15psi with the 3.25...the same as the 3.0 inch with other companies, this is why i think that the sizes are off. Maybe the 3.25 from SFPH is really 3.0 when measured the same way as the other pulley, and it says you shouldnt run anything under a 3.25 without a ECU reprogram..>W T F? i thought it was the 3.0 then u need reprogramming...another reason i think SFPH's sizes are off
ANY insight? or help is appreciated!!!!!
Old Dec 13, 2005 | 10:19 PM
Xenozx's Avatar
stick with GM's upgrades in april
Old Dec 13, 2005 | 10:20 PM
Jmc007's Avatar
I DID measure the stock SC pulley size ; it's 3.35" in effective diameter (top of the v where the belt sit) and it's 3.5" overall outside diameter.
Old Dec 13, 2005 | 10:22 PM
silverSS's Avatar
so what are you saying..the 3.25inch from SFPH is really like a 3.0 the other companies are advertising..if so that would make sense
Old Dec 13, 2005 | 10:32 PM
silverSS's Avatar
JMC007-- is the pulley technologies pulley the same as the "ebay pulley, or zzperformance pulely"??
where did you get yours, and how is it running?
Old Dec 13, 2005 | 10:34 PM
Jmc007's Avatar
Yes I get mine on E-Bay when it was available. It's running fine, no CEL, no knock retard, 3 PSI more boost (with by-pass valve selenoid disabled), great and cheap mod !
Old Dec 13, 2005 | 11:31 PM
ninja44's Avatar
Which line and which end did YOU plug?
Old Dec 14, 2005 | 12:00 AM
Drewfu$'s Avatar
ZZP makes great products and has always done good by me. Ofcourse there will be people on here who are going to bash them, but thats expected about any vendor. But they are a large vendor in the GP community, so don't worry about not getting any customer service or them ducking out with your money.
Old Dec 14, 2005 | 12:08 AM
JPK's Avatar
JPK
I bought one of the 2.8 pulleys and it looks great. Just like the stocker but smaller.
I haven't been able to put it on yet because my plans to buy the adjustable tensioner pulley bracket got foiled when I lost my job a couple of days ago.
Can't wait to throw it on my RL.
Old Dec 14, 2005 | 12:09 AM
JPK's Avatar
JPK
http://www.******************/forums/...ypass-mod.html
Old Dec 14, 2005 | 12:10 AM
patathSS's Avatar
One thing that would make me lean towards ZZP is the fact they are located in Grand Rapids, MI and it is a lot closer than SFPH. So this might have the opposite effect if I lived in Florida, depending how far away it is.
Old Dec 14, 2005 | 01:41 AM
zinner's Avatar
Moderator Alumni
I didn't note any difference with the SFPH 3.25, no more PSI, or power. The 3.0 SFPH I definetly noticed a difference.
Old Dec 14, 2005 | 11:05 AM
clownhair's Avatar
Its a quality piece I have one of there modular systems on my car and it works great. I had the SFPH modular on my car before and it also worked great.
Old Dec 14, 2005 | 11:34 AM
silverSS's Avatar
What if i get the 3.0 from zzPerf. should i run one step colder plugs? would this do anything? i mean just to be safe.
Old Dec 14, 2005 | 12:33 PM
max_boost's Avatar
Yes you should run a one step colder cooper plug. NGK BKR7E are pretty popular among Red Line owners.
Old Dec 14, 2005 | 01:02 PM
Jmc007's Avatar
Stock plugs works fine too ...
Old Dec 14, 2005 | 02:04 PM
2006ArrivalBlueSS's Avatar
Question
So let me get this straight. What I'm reading is that I can replace my stock pulley with a smaller one and expect to receive more boost, therefore more power. And the MINIMUM size I can go is 3.00" WITHOUT having to reflash the ECU or install a piggy-back system. Do I have this right??
Old Dec 14, 2005 | 02:15 PM
load97's Avatar
Post
Ive had sfph pulleys for my MP112 and they were fine(aside from high grit sanding the hub of the pulley to fit on the snout shaft); Ive never had zzp's pulley's, but Ive heard they are just fine. Ive had my issues about quality with them, but nothing to do with pulleys.
I didnt have a problem with sfph in regards to pulley sizes. Sorry I cant help you there.
Old Dec 14, 2005 | 07:49 PM
BlwnGP's Avatar
...or selling you something that is untested and when it breaks, telling you it was "installer error". But, I don't know anyone who has EVER done that before
ZZP has Ecotec specific press-on pulleys and a Ecotec specific MPS too. Looks like they are adding stuff every day.
I have bought lots of stuff from ZZP for my GTP and have always had great service and fast shipping. They also offer lots of honest advice over the phone.
Old Dec 14, 2005 | 08:20 PM
Jmc007's Avatar
You're damn right. A 3" pulley will give you 2-3 PSI more boost, roughly 10 to 15 more HP and same thing fot he torque, will boost sooner, will run great for 60$ a great mod.
Old Dec 14, 2005 | 08:58 PM
Thanks buddy...merci beaucoup!!!
Old Dec 14, 2005 | 10:19 PM
Jmc007's Avatar
It will help you also achieve a 14.15 @ 100 MPH quarter mile ...
Old Dec 16, 2005 | 12:42 PM
SFPH's Avatar
silverSS, our DUB 3.25" is an accurate 3.25" in pulley diameter, as are the other sizes we have for Eaton Model 62 Supercharger. All our pulley sizes are measured onto of the rib area, inside of the pulley itself, not in the bottom of the grooves, which supports the supercharger belt. Hope this helps.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
